top speed govenor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Wayne, this thread has received 16 replies and been viewed 1808 times.
post #1 of 17 (permalink) Old 04-09-2006, 03:36 PM Thread Starter
PSD owner
top speed govenor
Is there a way to disconnect the top speed govenor, or is it controlled by the cpu program only?
Wayne is offline
post #2 of 17 (permalink) Old 04-09-2006, 03:39 PM
u can hold the key forward on my dad's 6.0 when u hit the sped limiter and it will keep going...havent tried it on my 7.3 as it already goes over 100 with the chip i have..
Liftedpsd is offline
post #3 of 17 (permalink) Old 04-09-2006, 03:44 PM Thread Starter
PSD owner
Hold the key foward? Do you mean the ing. key, would'nt that engage the starter. I should mention its a 7.3L
Wayne is offline
post #4 of 17 (permalink) Old 04-09-2006, 03:50 PM
no ur in drive..you cant start the truck in drive..it wqill work on your 7.3 also..u just hold the ignition key forward when u hit the speed limiter
post #5 of 17 (permalink) Old 04-09-2006, 03:51 PM
or get a chip that disables it..its all up to you..but that is a free way to bypass the limiter..
post #6 of 17 (permalink) Old 04-09-2006, 05:38 PM
just curious how in the heck did you find that out? :roflmao:
or do i want to know
JLayne is offline
post #7 of 17 (permalink) Old 04-09-2006, 07:44 PM
TDG Singles Club #120
SUCK-SQUEEZE-BANG-BLOW's Avatar
do you have to continue holding it, or just flick it quick and keep going?
2001 F-350: Banks Stinger Plus kit, D.I.Y. intake, OttoMind with power pack tune, 285/75/16 Nitto Terra Grapplers.
TDG Singles Club Member #120
The Stang:
93 lx, mac long tubes-ceramic coated, mac cat back, Dr. Gas "X", mac cat H, 3:73's, pulleys, centerforce dual friction, 16* timing, 3g altenator, ac eliminator, smog pump bypass w/ short belt, Motorsport E cam, Cobra 1.7rr's, crane 44308-1 vavle springs, edelbrock dual roller timing set, 73maf, 70mm tb, 24lb injectors, adj. FP Reg, 190 lph fp, crane hi 6, Crane lx 92 coil, solid motor mounts, subframe connectors, motorsport "B" springs, X2C Boxer ST control arms, lakewood 50/50's, 5" monster tach.
Originally Posted by Adam View Post
Ricer math? Is that like... Wing + neons x APC decal = Bombshizzle?
www.myspace.com/christopherquinlivan
SUCK-SQUEEZE-BANG-BLOW is offline
post #8 of 17 (permalink) Old 04-09-2006, 07:45 PM
continue holding it, also i heard about it back when i got my 7.3 but never used it cuz i chipped it then i remembered it for the 6.0 and it works..It might make ur fuel guage read low but dont worry after a bit ti will come back up...
post #9 of 17 (permalink) Old 04-09-2006, 07:58 PM
I do all my own stunts
Send a message via MSN to kblackav8or
Just be aware that D and E rated tires are not rated for the speeds these trucks are capable of with the limiter disabled. There is a great deal of inertia generated at the RPM the tires start to turn over 100 and alot of steel in them to fail explosively. Probably rare but possible. The speed limiter probably has more to do with the tires then anything else. Now if you can find some adaquately rated tires then take her to a safe/legal venue and have at it.
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
post #10 of 17 (permalink) Old 04-09-2006, 08:59 PM
:blah: Hey dont spoil all of our dangerous fun!!!
StrokerAce is offline
