EGT Question? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigdiesel502, this thread has received 9 replies and been viewed 497 times.
post #1 of 10 (permalink) Old 04-11-2006, 02:25 AM Thread Starter
EGT Question?
I seem to be hitting 1250 easy at WOT. Is that normal in the 100 horse setting? Also at cruising speed (70-75 mph) EGT was right at 600 with stock turbo, but with new BallBuster (installed today!) I seem to be about 100 degrees higher. Just to clarify I always run in the 100 horse setting. Stock or BallBuster. Sorry if it's a stupid question but I was just wondering. Thanks.
bigdiesel502 is offline
post #2 of 10 (permalink) Old 04-11-2006, 02:31 AM
CSIPSD's Avatar
I would say a boost leak somewhere but the cruse thing stumps me. I'm betting on a boost leak! Check the up pipes, I know I have a small leak there! I just don't feel like fixing it right now...
CSIPSD is offline
post #3 of 10 (permalink) Old 04-11-2006, 02:35 AM Thread Starter
Stupid question. What's an up pipe??
post #4 of 10 (permalink) Old 04-11-2006, 02:43 AM
CSIPSD's Avatar
From the manifolds to the turbo collector, there are two pipes on each side... very temperamental leakers!
CSIPSD is offline
post #5 of 10 (permalink) Old 04-11-2006, 02:50 AM Thread Starter
How hard is that to fix??
post #6 of 10 (permalink) Old 04-11-2006, 03:15 AM
CSIPSD's Avatar
What you need to do is test for boost leaks, I built a little rig this weekend for just that reason.
https://www.thedieselgarage.com/forum...ad.php?t=13713
I think that link will work
CSIPSD is offline
post #7 of 10 (permalink) Old 04-11-2006, 12:11 PM Thread Starter
Thanks for all the info CSIPSD. I appreciate your knowledge.:Thumbup:
post #8 of 10 (permalink) Old 04-12-2006, 09:26 PM
FORD For Off Road Driving
Muddin's Avatar
1250 @ WOT on the hwy in 100 hp setting is not bad. As long as you dont hit the 1300+ for an extended period of time you will be fine.
600 on the hwy cruising 70 is normal. Up pipes are a PITA to mess with. It's easier to drop the tranny out of the truck and sit under it in the tranny compartment than to try to replace them from up top.
Truck #1 info: Early '99, 7.3L PSD, 4x4, Ext. Cab.
Mods: BTS TRANNY!!, DP Tuner, Rockwell 2 1/2 ton military axles!
Truck #2 info:'02, 7.3L PSD, 6spd, 4x4, DRW, CC.
Mods: B&W gooseneck hitch
Muddin
Muddin is offline
post #9 of 10 (permalink) Old 04-12-2006, 09:30 PM
CSIPSD's Avatar
The up pipes are about the only job I will let Ford fix!!! I almost feel for the tech that gets stuck with it!!!
CSIPSD is offline
post #10 of 10 (permalink) Old 04-13-2006, 01:23 PM Thread Starter
Sounds like I'm going to be leaving the up pipes alone for a while! If that's what it is. A buddy of mine said he had to replace the gaskets on a '02 SD, but he had the transmission out and he couldn't have done it otherwise. Thanks again for replying so quick! You guys are great!!
