97 7.3 manual shaking/rattling while idle??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Tom2464, this thread has received 1 replies and been viewed 2087 times.
post #1 of 2 (permalink) Old 06-30-2014, 01:02 AM Thread Starter
I have a 97 7.3 with a 6 speed manual trans. It dosent allways do it but usually when i push in the clutch coming to a stop it shakes/rattles pretty bad it has done it for a few years now but is doing it more often and getting worse. It has 200k miles on it and has a brand new trans./ flywheel/ clutch put it at 80,000 miles. I am hoping its not the fly wheel but can someone please give me a few ideas of what it would be. Thank you
Tom2464 is offline
post #2 of 2 (permalink) Old 07-01-2014, 02:02 AM
Stuck in Commiefornia...
IdahoF350's Avatar
So the flywheel, clutch, and transmission were new 120,000 miles ago. If it's a dual mass flywheel, you can bet that is your noise and shake source, probably due to a failed pilot bearing on the input shaft. If you drive them that way long enough it tears up the internals of the transmission too. Pull the starter/inspection plate, and reach in and try and rock the pressure plate on the flywheel. If it moves more than a 1/6" or so, you've got your answer.
2000 Excursion XLT 4x4
IdahoF350 is offline
The Following User Says Thank You to IdahoF350 For this addition to TDG:
Tom2464 (07-01-2014)
truck is shaking on idle at a red light strokin 03 f250 2003-2007 6.0L Power Stroke 13 01-16-2009 11:35 AM
Engine really rough idle and shaking very aggressive. dieselram55 1994-2003 7.3L Power Stroke 9 12-18-2007 12:35 AM
High idle not an option on manual transmission? notouch 6.7L Cummins (2007.5-2011) 7 11-01-2007 08:44 PM
Rough Idle or something Rattling bad WBV06CTD 5.9L Cummins (1998.5-2002) 11 06-20-2007 07:41 AM
Rattling noise at idle Jawahe 1994-2003 7.3L Power Stroke 8 02-15-2007 07:59 PM
