99 F350 Runs for a few minutes and dies... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fire1009, this thread has received 3 replies and been viewed 1042 times.
post #1 of 4 (permalink) Old 07-14-2014, 06:34 PM Thread Starter
I'm having some problems with my PSD... really the first since it was new.
It will run for a few minutes and then it just dies. Replaced the engine fuel filter and no change. I've checked the codes and there are none. I replaced the CPS since I've been carrying it around in the glove box for the last ten years and that did not change anything.
I did by the way have to change the alternator a few weeks ago but it seemed to run ok after the new alternator... no idea if that has any effect but it is charging correctly now and the batteries are ok.
Prior to the current issue a few days ago it seemed to idle rough and when driving it the throttle response was very erratic.
Any ideas?
fire1009 is offline
post #2 of 4 (permalink) Old 07-16-2014, 07:12 PM
Stuck in Commiefornia...
IdahoF350's Avatar
Check base fuel pressure at the filter, running. There is a test port by the fuel bowl. No codes and random stall with idle issues sounds like lack of fuel.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #3 of 4 (permalink) Old 10-14-2014, 02:01 AM
Hosspuller's Avatar
Friend of mine had same issue, He changed high pressure oil pump and still same issue. Then he changed the fuel tank screen and fixed his problem. Hope this helps you solve yours too...
Just another wanna b....
Hosspuller is offline
post #4 of 4 (permalink) Old 10-14-2014, 02:50 AM
bpogue's Avatar
I agree that first you need to be able to monitor high pressure oil and fuel to determine if either of these are the cause. There are ports in the heads that you can use to install a fuel pressure gauge. Some scanners can monitor high pressure oil. Once the truck dies, I would recommend opening up the high pressure oil reservoir and fuel bowl to check levels of both of these fluids.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
Runs Then Dies blackcloud02 1994-2003 7.3L Power Stroke 7 02-05-2014 03:12 AM
2007 F350 6.0L runs rough looses power and dies Dual350 2003-2007 6.0L Power Stroke 7 03-06-2012 02:44 AM
Starts runs a little then dies. 04lariatfx4crewcab 2003-2007 6.0L Power Stroke 2 11-08-2010 01:10 PM
Runs fine then dies ToddPSD 1994-2003 7.3L Power Stroke 4 05-14-2010 11:31 PM
runs then dies midnightcaper 1994-2003 7.3L Power Stroke 5 09-11-2006 01:36 AM
