HELP!!! Its sputterin and blowing white smoke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Matty69, this thread has received 12 replies and been viewed 2817 times.
post #1 of 13 (permalink) Old 04-17-2006, 06:12 PM Thread Starter
Hey Guys,
I really need some help here. Yesterday I started the truck up, it idled a little on the rough side (which it seems to be doing a lot of lately), I let it warm up and then went for a short ride. I got out to the highway and kicked er down, lots of black smoke:smoke: then all of a sudden it chugged real hard and then lots of white smoke :shrug: then black smoke again. I got to my parents house and shut the truck off. Four hours later went home, now upon startup it smokes really really really bad. Blueish white smoke.
When I stomp on it, it bellows black smoke but I can feel it missing.
When I got back home I removed the SCT Programmer from ATS and put the stock setting back in. It seemed to run a little better. Then i put my banks BIG HOSS level 5 chip in to see if it made a difference. Now it seemed to run even worse and really started sputtering and missing. When I press on the throttle whitish smoke just bellows out of her and the truck is definately warmed up by now!!
Any thoughts before I take er to the stealership!
Thanks,
Matty:shrug:
Matty69 is offline
post #2 of 13 (permalink) Old 04-17-2006, 09:14 PM
Do you pull any codes?Sounds like a Injector problem, fuel pump turbo,
Do you build any Boost?How hot does she get EGT's Wise?
White smoke is unburnt fuel.Black smoke is wasted fuel and Blue is oil.
Mike
kainers is offline
post #3 of 13 (permalink) Old 04-17-2006, 09:23 PM
UVC harness?
JLayne is offline
post #4 of 13 (permalink) Old 04-18-2006, 02:28 AM Thread Starter
I didn't pull any codes. Will have to do that. Yes she builds boost just fine.
Matty69 is offline
post #5 of 13 (permalink) Old 04-18-2006, 03:50 AM
it sounds similar to my problem i had a few months ago that turned out to be the IDM.
Except, my truck tried to run away.
~CrazyDiesel~ is offline
post #6 of 13 (permalink) Old 04-18-2006, 06:45 AM
If you take it to the dealer take evvvvverything off of it. Unless your dealer is ok with those mods, which most wouldn't be. Good luck hopefully its nothing serious.
P.S. I'd take off that propane if I were you not too good on your rods
f250power is offline
post #7 of 13 (permalink) Old 04-19-2006, 05:30 PM
if it turns out to be the IDM make sure they check the UVC harness more than once...
a bad UVC harness will take out a new IDM and is possibly the reason the first went out.... don't ask me how i know this
JLayne is offline
post #8 of 13 (permalink) Old 04-27-2006, 07:10 PM
could be a head gasket or maby just the turbo?
----------------------------------------------------------------------------------------------------------------------- 95 psd extended cab long bed -----------------------------------------------------------
Airaid itntake, 5inch duels , 35inch baha claws, s-400 turbo, ats tranny, ats 5 star converter, Banks intercooler, 3.5inch lift, Banks six gun, piller pod –pyro-boost-tranny temp, texas style bumpers. Ohhhhh yeah
BiG_stroke07 is offline
post #9 of 13 (permalink) Old 05-05-2006, 03:58 AM
Its the cam sensor. Just replace it and put another one in the glove box cause its gonna happen again.
betitallgambler is offline
post #10 of 13 (permalink) Old 05-05-2006, 06:19 AM
ummm, no
