02 7.3l intake air temp sensor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 2 replies and been viewed 1319 times.
post #1 of 3 (permalink) Old 09-17-2014, 01:08 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
My 02 Excursion keeps "breaking". The little thermal probe inside breaks off. I then get a code. I originally bought the replacement from Autozone and it has a lifetime warranty the sensor is covered. My question is am I installing the sensor incorrectly or is it just a POS part? I have tried to orient the sensor in different directions but nothing has stopped it. I have replaced the sensor 4 times in three years. Thanks in advance.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #2 of 3 (permalink) Old 09-17-2014, 04:19 PM
Stuck in Commiefornia...
IdahoF350's Avatar
I'd grab a Ford/Motorcraft sensor. There are some parts from Autozone that I would have no hesitation running, but sensors aren't one of them. Same as the CPS. I haven't seen many AIT sensor failures in 20 years, but I have seen what you're talking about. I always marked and oriented the sensor so that the probe was protected from the direct force of the air on forced induction applications. Final thought is use a bit of ultra grey instead of Teflon tape, and only tighten it just past the point of hand tight with just a socket to get the alignment.
2000 Excursion XLT 4x4
IdahoF350 is offline
The Following User Says Thank You to IdahoF350 For this addition to TDG:
jdydiesel (09-19-2014)
post #3 of 3 (permalink) Old 09-19-2014, 02:25 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
Thanks Idaho. I will see what a Motorcraft part costs and weigh it against the free replacement from Autozone. I have also made sure that I align the sensor so the it is protected from the sides of the sensor.
Jason
fooling the intake air temp sensor ? turbo8781 24 Valve Performance 4 09-11-2011 08:51 PM
7.3l Intake air temp sensor jdydiesel 1994-2003 7.3L Power Stroke 17 05-12-2011 08:20 PM
ambient air temp sensor, 04 cummins jbryant 5.9L Cummins (2003-2007.5) 4 04-23-2009 10:50 AM
Outside ambient air temp sensor testing WasGas General Ford Truck and Excursion 2 02-25-2009 05:52 AM
air temp sensor droolinforparts 2003-2007 6.0L Power Stroke 4 03-12-2008 02:06 AM
