2001 F250 transmission/driveline capability - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fastback, this thread has received 3 replies and been viewed 1063 times.
post #1 of 4 (permalink) Old 10-13-2014, 09:44 AM Thread Starter
Greasy Greenhorn
I have an '01 F250 with 215,XXX miles on it and has been pretty well maintained. I'm planning on doing some upgrades pretty soon. Possibly looking to get into the 400hp and 850lft/lb range. What are the max hp/torque numbers the stock trans and driveline can handle?
Fastback is offline
post #2 of 4 (permalink) Old 10-17-2014, 06:21 AM
Stuck in Commiefornia...
IdahoF350's Avatar
So your power goals are very similar to my own. Your post doesn't say and the Autoguide ap doesn't show signatures if you have it listed so I'm going to assume you have a 4R100 automatic transmission and not a ZF 6S-650 6-speed manual which would need nothing much more than a clutch upgrade.
The 4R100 can be a perfectly competent, if not brilliant transmission for your power level. In stock form, especially if it has 215k on it, it will not survive for long behind that power level regardless of the ancillary upgrades you perform. The stock torque converter will not handle the power well either. Heat from the additional power will be a significant problem but is easily remedied with a 6.0L transmission cooler and a deep sump pan. It would serve you best to not install this items until you upgrade the transmission.
For myself, I plan on running an aftermarket billet converter with a slightly lower than stock stall speed of about 1800-2000 based on the intended torque production (my stock converter stalls at 2400rpm now with a tuned stock engine) and increased lockup clutch capacity. A proper 4R100 built with the upgraded parts to handle up to 1000lb/ft of torque, good clutches, upgraded hard parts, possibly a BTS valve body, a deep cast pan, and a 6.0L (03-07) transmission cooler.
Now, the transfer case on the 4wd models just needs good clean fluid, in 2hi you'll never break it, but drag racing in 4hi is another thing all together, and you might just want to have a spare on hand.
Driveshafts are often overlooked. Take more of the stock driveshafts on some of the newer trucks like the 2014 Ram, and they're running 5"+ aluminum prop shafts to the rear. I'm not saying that's necessary, but that's the horsepower and torque level you're attempting to make and they have a margin of additional strength engineered into the driveshafts on the new trucks as well. At the bare minimum, you want to invest in new heavy duty universal joints, a new carrier bearing, and minimally an inspection, cleaning, and lubrication of the slip yoke, possibly replacement if wear dictates it.
The axles should be fine, again, service them with high quality fluid. Replacing the bearings probably isn't necessary, but they should be checked for condition and properly preloaded for used bearings. It never hurts to check the emergency brake components and rebuild them if needed. Same applies to the front axle, only with the hubs and ball joints being the components to pay attention to.
Good luck with your pursuit of power. Keep us updated with your progress.
Sent by my right thumb!
2000 Excursion XLT 4x4
IdahoF350 is offline
The Following User Says Thank You to IdahoF350 For this addition to TDG:
Fastback (10-18-2014)
post #3 of 4 (permalink) Old 10-18-2014, 05:20 AM Thread Starter
Greasy Greenhorn
Preeshadit. Thx for all the info. It is a 4R100 auto. Most of my mechanical background is from building, working on, and racing a twin turbo mustang I had a few years back in the True Street 10.0 class. So I'm still pretty green on all the inner workings of these types of vehicles.
I bought my F250 as a tow rig. I've since sold the car, paid off the truck, started school for diesel mechanics (42 of 70 weeks thru) ,and discovered the wonderful world of the NHRDA. I'm not intending on racing the truck but definitely wanna make a noteworthy street truck out of it. Anyway, I will definitely post updates on the progress of it.
Fastback is offline
post #4 of 4 (permalink) Old 10-20-2014, 01:12 AM
IdahoF350's Avatar
I've been in and around the performance aftermarket my whole life, started turning wrenches on cars over 25 years ago. My interests have always been centered on road racing, and I've had some pretty competent cars in my time.
The thing I've found is that fun in a car starts when the power to weight ratio crosses 10lbs per horsepower, 10:1 in a good chassis is no slouch with a goo driver. 8:1 used to be the beginning of ultra high performance, but these days, it's 6:1 in cars like the C6 Z06.
Diesels it's torque not horsepower, and a 7,500lb F-350 Crew Cab Long bed with about 750 lb/ft of torque is a blast and gives you that 10:1 ratio. Getting up to an 8:1 or even 7:1 ratio with a 7.3 is not unheard of these days, 7:1 meaning you'd have about 1050-1100 lb/ft of torque at 7500lbs. There are several 6.4 Powerstrokes, countless Duramax, and Cummins powered trucks making this kind of power and driven daily.
Just depends on how far you want to push the 7.3 and your finances. I like your 400/850 goal, that is a super realistic number for this engine, and why I'm looking at essentially the same range.
2001 f250 martin0371 1994-2003 7.3L Power Stroke 8 08-04-2009 12:27 AM
F250 driveline clunk buckslayr 2008-2010 6.4L Power Stroke 1 04-29-2008 03:04 AM
2001 F350 transmission upgrades. kofire 1994-2003 7.3L Power Stroke 7 12-16-2007 06:23 AM
New 2001 F250 wcade 1994-2003 7.3L Power Stroke 11 12-15-2006 04:37 PM
HPOP capability? SICKS-O 1994-2003 7.3L Power Stroke 3 07-14-2006 02:45 PM
