97 7.3 LIter injector Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jaadc01, this thread has received 4 replies and been viewed 673 times.
post #1 of 5 (permalink) Old 04-21-2006, 01:28 AM Thread Starter
does anyone know the specifics on diagnosing a faulty injector for this particular truck. ever so slight vibration
97 F250 Heavy duty 4.11 Gearing and a 5 speed manual transmission
Jaadc01 is offline
post #2 of 5 (permalink) Old 04-21-2006, 03:19 AM
BJS
do you have a dual mass flywheel still if so that's more than likely your problem
otherwise a cylinder contribution test & buzz test are the diagnosis tests
BJS is offline
post #3 of 5 (permalink) Old 04-21-2006, 04:59 AM Thread Starter
injectors 7.3 liter
still have dmfw with 75000 miles. flywheel has 3/4 inch of movement. is this acceptable? i have heard that it is. what is needed to do a cylinder contribution test. thanks for the reply.
Jaadc01 is offline
post #4 of 5 (permalink) Old 04-21-2006, 05:30 AM
a good scanner will do a cyl con test and injector buzz test. it does sound like your duel massflywheel. when you push in the clutch does the vibration change? if you know anyone with a lab scope, the injectors can be scoped to find a bad one, even if they pass the contrubution test the scanners do.
imported_diesel71 is offline
post #5 of 5 (permalink) Old 07-03-2006, 11:41 AM
hey man did you ever find out about your truck was it the clutch or injector problems? i am having the same problems with my 97. i think mine is injector problems
diesel charlie is offline
