99 7.3 random no start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acegreaser, this thread has received 3 replies and been viewed 1338 times.
post #1 of 4 (permalink) Old 12-29-2014, 01:14 AM Thread Starter
Thought it was cold start related at first.new glow plugs,no codes,power out to glow plugs.crank no smoke,icp is 2000.buzzed injectors all good,after cranking a couple times white smoke appears than starts.had a snap on modis hooked up and volt meter on GPR everything looks ok.when you hammer the throttle no response sometimes just idles,but the scan tool shows the tps voltage change and micro switch change from on to off idle.but if you accelerate normal it works fine.shut the truck off it might start right back up or no start no smoke.no codes present.it sometimes hiccups going down the road or just goes to idle but no codes thrown
acegreaser is offline
post #2 of 4 (permalink) Old 12-30-2014, 03:34 AM
Golddigger's Avatar
Have you checked the plugs for the valve covers?
2002 F-350 CC, Shortbed, 4X4, rebuilt 7.3, EBV brake, 4" dual exhaust, B&D compressor wheel, head studs, Gear head performance 6 pos, Banks Big Head, built 4R100 w/triple disc torque conv, Shift kit, 204K, B&W Hitch and 5th wheel companion, Superlift Air Bags, 35 x 12.50 x 17 BFG KM2:
The veiws expressed are purely opinion. I in no way take responsibility for any actions or damage as a result of trying this at home.
Local 3 OPERATORS UNION
2005 Chevy 7500 C-7/Allison, Service box off of my '93 Int
Golddigger is offline
post #3 of 4 (permalink) Old 12-31-2014, 02:27 AM Thread Starter
Yes
post #4 of 4 (permalink) Old 12-31-2014, 02:31 AM
Golddigger's Avatar
Cam sensor? I did have an '02 that the tps went bad and was showing change even though it was the problem.
random parts AmarilloSD Ford Parts 0 02-21-2011 03:04 AM
random shuddering ford7.3sd 1994-2003 7.3L Power Stroke 1 04-01-2008 04:36 AM
Random No Start Possibly Maybe Solved! aldo_45030 1994-2003 7.3L Power Stroke 2 07-05-2007 01:18 AM
random question imported_duck 5.9L Cummins (1998.5-2002) 4 02-26-2007 09:22 PM
Random Access doublereeder Introductions 10 02-15-2007 02:12 AM
