Got my new turbo... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CSIPSD, this thread has received 12 replies and been viewed 814 times.
post #1 of 13 (permalink) Old 04-26-2006, 06:04 PM Thread Starter
CSIPSD's Avatar
Got my new turbo...
Got a few questions,
1. I thought the compresser side was not ported, this one is?
2. No where does it say GTP-38r, could this be a ATS bb?
3. The guy bought it from LIPD (pm sent) and said he had less then 500 miles on it. From what I can see I beleve him. What do you think>
4. 1.00 ar on both the compresser side and the drive side... Normal?
5. I'm not going to install it for about three weeks, so I've got some time to "tweak" it so to speak. Anyone ever polished the compresser side? Just to purty it up?
I'm not going to C coat it or anything, but anything else I should look for?
ID:	5049   Click image for larger version
ID:	5050   Click image for larger version
ID:	5051   Click image for larger version
ID:	5052   Click image for larger version
Name:	tag plate.JPG
CSIPSD is offline
post #2 of 13 (permalink) Old 04-26-2006, 08:22 PM
Wish I Could Help...
NMU98 is offline
post #3 of 13 (permalink) Old 04-26-2006, 08:27 PM
1. You can't see in the pictures, but look at the shroud around the compresser wheel....you should see a machined "slit" circling all around the compresser wheel to allow air to bleed back to the Inducer (wheel inlet).
2. It is a Garrett GTP-38R...so u didn't get ripped.
3. Looks like low miles.
4. yes, 1.0 on each side is normal.
5. rough cast disipitates heat better than a polished surface...disipitating heat on the compresser side is a good thing.
Hammer
TheHammer69 is offline
post #4 of 13 (permalink) Old 04-26-2006, 08:29 PM Thread Starter
CSIPSD's Avatar
Thanks, is the porting normal on a BB?
CSIPSD is offline
post #5 of 13 (permalink) Old 04-26-2006, 08:34 PM
it's normal on any shrouded wheel. the port is known as a "inducer bleed ring", and if a turbo is built without an Inducer bleed, then there is no need for the shroud and would have an inlet similar to the stock turbo.
BTW...www.dieselsite.com offers porting of the existing Inducer bleed to prevent the surge that is known to occur on the BB turbos when really pushed.
Hammer
post #6 of 13 (permalink) Old 04-27-2006, 03:27 AM
moose99psd's Avatar
i want new turbo issed: issed: stupid early 99 pedistal...:blah: :blah: whys he get all the new toys ?: : :
moose99psd is offline
post #7 of 13 (permalink) Old 04-27-2006, 03:43 AM
Diesel Dog's Avatar
Looks good!!:Thumbup:
Diesel Dog is offline
post #8 of 13 (permalink) Old 04-27-2006, 06:16 AM Thread Starter
CSIPSD's Avatar
Do you still love the whine of your 99:shrug: :
And yes I do get lots of toys, some even in pairs...:evil: :
CSIPSD is offline
post #9 of 13 (permalink) Old 04-27-2006, 12:12 PM
Tornsteel's Avatar
You're going to like the whistle. I just got mine installed. I had high expectations for the whistle and I'm pleased. I just hope that it'll stay that way.on:
2006 XLT 6.0, 72,000 miles. First owner. Build date 10/05, CC,LB,3.73LS,SRW,ISSPRO Pyro-Boost-Trans on the APillar,ARP Studs,Stock HG's,ELITE SCT Tadd's Tunes,Sinister SCT,Innovative tunes,EGR delete,4" turbo back dual exhst, zoodad, ccv mod, Coolant bypass filter, Cage leveling kit,upfitter high idle, running Amsoil 3000 with Archoil, 6.4 banjo's, Blue spring, 03 Turbo w/ 03 pedestal.
Issues: Rear main seal at 1'700 mls. EGR valve, EGR cooler and Oil cooler @ about 43k, Stock Head Gaskets @55k, Black Onyx HG's @72k.
https://www.thedieselgarage.com/galle...028_393362.jpg
Sean H
Tornsteel is offline
post #10 of 13 (permalink) Old 04-27-2006, 01:53 PM
it will stay loud.
LIPD is offline
