Need help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by legacy76, this thread has received 1 replies and been viewed 517 times.
post #1 of 2 (permalink) Old 04-29-2006, 09:47 PM Thread Starter
Need help
I broke my water seperator on my 96 Ford F-250 ps. The sending unit was leaking diesel so I tried to tighten it a bit and broke the threaded hole that the sending unit fits into. I have everything loose except there is a solid line coming off the bottom of the water seperator and runs up and under the fuel filter canister. The only way I can see getting to the line is by taking the fuel filter canister off but I 'm not sure how hard that is to do. Any help would be appreciated.
legacy76 is offline
post #2 of 2 (permalink) Old 04-30-2006, 12:47 AM
It would be way better to take the hole fuel canister out? its fairly easy unhook the electical connecthions the 2 fuel lines. look down on the right and left sides of the canister you will see a bolt one per side remove them, they will take a 13 mm socket, losen the hose clamp on the blue fuel line on the bottom hose and the blue hose on the right. wigel it a bit and it should come out? :Thumbup:
imported_diesel71 is offline
