7.3 dampr ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_diesel71, this thread has received 18 replies and been viewed 981 times.
post #1 of 19 (permalink) Old 05-02-2006, 05:19 AM Thread Starter
Question 7.3 dampr ?
I put a fluidampr on my 6.0 sunday and posted on it in the 6.0 form. has any of you 7.3 guys tried one ?????
imported_diesel71 is offline
post #2 of 19 (permalink) Old 05-02-2006, 06:44 AM
I am interested in getting one.It is a cheap mod when you compare it to inj or turbos.
Do you have to do the front seal or crank seal on a 7.3 like you did on your 6.0?
Mike
kainers is offline
post #3 of 19 (permalink) Old 05-02-2006, 12:49 PM
Never heard of a fluid damper on a 7.3 (or a 6.0 for that matter). Enlighten me.
imported_BigGreen is offline
post #4 of 19 (permalink) Old 05-02-2006, 03:06 PM
Mike
It is not necessary to replace the crank seal on a Fluidampr install unless the seal is worn out.
Basically a Fluidampr controls torsional vibration from the crankshaft better than the stock rubber damper. The stock rubber damper is designed from the factory to absorb the peak vibration at a specific rpm. Once you have done any mods to the engine, you have shifted where the peak vibration occurs to a different rpm. The stock damper will no longer protect your engine like it was designed. The advantage of the Fluidampr is that it does not matter where the peak vibration occurs, it will absorb vibration through out the entire rpm range. That is why you will see viscous dampers on all heavy duty diesel engines, they control high torsional vibrations much better than rubber dampers.
For more information please see the link below:
http://www.fluidampr.com/downloads/diesel_fluidampr.pdf
I hope this answers your questions, if anyone has any other questions please let me know.
Thanks.
Dan
Fluidampr is offline
post #5 of 19 (permalink) Old 05-02-2006, 03:50 PM
I've bought one for my engine build up but the motor is not running yet. After talking to a lot of performance engine builders it just made good sense.
Hopefully, I'll soon have my nozzle issue fixed and we'll see how the entire truck runs.
Suns_PSD is offline
post #6 of 19 (permalink) Old 05-02-2006, 09:46 PM
how hard is it to install just a few bolts and away you go or do you need a puller?What damage can I cause doing it okie backyard mech style?
Thanks
Mike
kainers is offline
post #7 of 19 (permalink) Old 05-03-2006, 02:11 AM
Supporting Vendor
Thanks
Mike
One large bolt, and a puller.
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #8 of 19 (permalink) Old 05-03-2006, 02:48 AM Thread Starter
[QUOTE=kainers]I am interested in getting one.It is a cheap mod when you compare it to inj or turbos.
I only had to do the seal because it was leaking, not bad but i was working thier anyway. if you do one, i would suggest you rent or buy a dampr puller and installer for your 7.3. :Thumbup:
post #9 of 19 (permalink) Old 05-03-2006, 02:53 AM
any sponsors carry these things?
kainers is offline
post #10 of 19 (permalink) Old 05-03-2006, 02:59 AM Thread Starter
You should be able to rent them from your local checker or autozone ? if you were close i would lend you mine. :shrug:
