its a mystery - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DieselDadio, this thread has received 2 replies and been viewed 875 times.
post #1 of 3 (permalink) Old 05-05-2006, 01:01 AM Thread Starter
its a mystery
just driving in town today and looked up at pyro and it was going craaaaazy needle was floppin back and forth then it hit the stop at hot, stayed there for 15 seconds,went to cold, then went back to normal. any ideas? it is an autometer about one year old. thanks kirk :shrug:
DieselDadio is offline
post #2 of 3 (permalink) Old 05-05-2006, 01:04 AM
Addicted Mechanic
Send a message via AIM to CLR95
I would check your power and ground sources... mine use to mess around when the ground got loose.. just an idea:shrug:
- C.R.
Ford Diesel Tech/Junkie
OLD95 F250 XLT Reg Cab 4x4 7.3 Hand Shaker
NEW04 F250 Lariat Crew Cab 4x4 6.0 Auto Mods XCAL 2, Custom Exhaust exiting in front of rear tire, 3 pillar pod with Isspro Gauges
CLR95 is offline
post #3 of 3 (permalink) Old 05-05-2006, 03:29 AM
:agreed: if your power and ground are ok, its probably the gauge. iv only seen one egt tip that was bad, the gauge on it read zero only.
imported_diesel71 is offline
