1995 7.3L not cranking - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tylers503, this thread has received 1 replies and been viewed 955 times.
post #1 of 2 (permalink) Old 08-31-2015, 11:00 PM Thread Starter
Send a message via Skype™ to tylers503
Unhappy 1995 7.3L not cranking
So i replaced injector O rings went ahead put them back in i went to crank it over i got 3 hard cranks and then it stopped cranking i took the glow plugs out and cranked it manually till all the diesel came out i heard if u let the injectors drain all the diesel in itll hydro lock it so i did all that then went to start it i get a click every time i go and turn the key so i got the starter tested it was dead so i got a new starter $200 from oriellys hooked it up same stuff happened click every time i went to jump it off a solenoid on the body and it doesnt even arch or spark when u touch the 2 bolts together with a screwdriver so im lost id love to get this truck to start it was running 2 weeks ago the injectors were leaking oil past the O rings.
owner of a 1995 7.3L powerstroke
tylers503 is offline
post #2 of 2 (permalink) Old 09-01-2015, 01:24 PM
Old Fart
dbennett48's Avatar
You had better figure out why your injector(s) are leaking before you throw $$$ at the starter. I would replace all of them with re-manufactured ones and replace the starter.
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
466E Not Cranking ajwsurra Medium and Heavy Duty 1 02-28-2011 12:44 AM
slow cranking old-red-2 7.3L and 6.9 IDI (Pre 1994) 11 05-05-2008 09:49 AM
extended cranking skippy 2003-2007 6.0L Power Stroke 17 04-25-2008 12:14 AM
Slow cranking TLadd 6.5L Diesel Engine 1 03-22-2008 02:16 PM
cranking time imported_06F450 2003-2007 6.0L Power Stroke 9 09-24-2007 10:39 AM
