loss of boost - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stroke250, this thread has received 6 replies and been viewed 851 times.
post #1 of 7 (permalink) Old 05-10-2006, 02:14 AM Thread Starter
strokenasty
loss of boost
i used to getting close to 30 psi of boost on the 140hp setting that i have only had installed since last august. now i am only getting about 20 psi max. what could be the problem? i dont have any codes. everything runs fine. boost leak? ebpv? wastegate? any info would be much appreciated.:HappyMugs
2003 GMC Lb7 EXT CAB SHORT BED w/ parts on it....:evil:
MERCHANT AUTOMOTIVE
SOLD:2001 Ford F-250 4x4:109,098 Miles, Autometer Ultralite Gauges(Pyro,Trans,Boost), TS Chip(high idle,stock,50,75,100,140+ settings: PureDieselPower), 6.5 Inch Pro Comp lift 315/75/16 Goodyear Wrangler MT/Rs, Banks Transcommand, Banks Exhaust,Wicked Wheel(Dieselsite), Engine/Intercooler Boots(Dieselsite), AirForceOne Intake, Husky Floor Liners, Boost Tube(PureDieselPower), Zoodad Mod Boost Relief Valve(PureDieselPower) HX Mod(DieselSite), Regulator Shim Kit:65 psi(DieselInnovations), Amsoil in engine(5W-30 HDD),transmission(ATF),front/rear differentials(Severe Gear 75W-90 Front,75W-140 Rear),Amsoil dual by-pass filtration, Coolant Filter(Dieselsite) 203 Stat(Dieselsite), Evans NPG+Coolant(Dieselsite) TQ Lockup(Dfuser)
stroke250 is offline
post #2 of 7 (permalink) Old 05-10-2006, 04:06 AM
#1 check air filter and intake for a restriction. #2 check intrcooler boots. look for an exhaust leak on the up pipes and y . #3 make sure the map hose is not plugged or pinched. #4 check the waste gate lever and actuator. #5 check your fuel pressure at 2500-3000 rpm under a load [climbing a hill or with the vehicle fully loaded]. #6 plugged green wastegate hose or port in the charge air intake to the turbo. a wastegated turbo is designed to reach maximum boost sooner than a conventional turbo,but overboosting will cause damage to the turbo.:Thumbup:
imported_diesel71 is offline
post #3 of 7 (permalink) Old 05-10-2006, 06:46 AM
<img src="http://static.verticalscope.com/images/vb/badges/vendorBadge.gif" border="0" />
Strictly Diesel's Avatar
Check to make sure that the Boost Relief Valve isn't stuck open.
Dennis Schroeder - Co-Owner of Strictly Diesel
Strictly Diesel Webstore / [email protected]
LIKE US on FACEBOOK! / Check Us Out on YOUTUBE!
Race Truck :: 6050# / 11.31 @ 120mph / Best 60' of 1.56 ... with "Built" Race Engine (Fuel Only!)
Race Truck :: 5980# / 10.965 @ 124mph / Best 60' of 1.54 ... with "Built" Race Engine (Nitrous)
Strictly Diesel is offline
post #4 of 7 (permalink) Old 05-10-2006, 08:52 AM
TDG Singles Club #120
SUCK-SQUEEZE-BANG-BLOW's Avatar
check the oil level. the fuel system runs off of oil pressure, if you are low, it will run rough, tough to start/stay running and result in a loss of boost.
i know it sounds stupid but it's worth a look.
just my 2 cents.
doesn't cost anything either.
2001 F-350: Banks Stinger Plus kit, D.I.Y. intake, OttoMind with power pack tune, 285/75/16 Nitto Terra Grapplers.
TDG Singles Club Member #120
The Stang:
93 lx, mac long tubes-ceramic coated, mac cat back, Dr. Gas "X", mac cat H, 3:73's, pulleys, centerforce dual friction, 16* timing, 3g altenator, ac eliminator, smog pump bypass w/ short belt, Motorsport E cam, Cobra 1.7rr's, crane 44308-1 vavle springs, edelbrock dual roller timing set, 73maf, 70mm tb, 24lb injectors, adj. FP Reg, 190 lph fp, crane hi 6, Crane lx 92 coil, solid motor mounts, subframe connectors, motorsport "B" springs, X2C Boxer ST control arms, lakewood 50/50's, 5" monster tach.
Originally Posted by Adam View Post
Ricer math? Is that like... Wing + neons x APC decal = Bombshizzle?
www.myspace.com/christopherquinlivan
SUCK-SQUEEZE-BANG-BLOW is offline
post #5 of 7 (permalink) Old 05-10-2006, 12:11 PM
Even with a stuck open relief valve he should be able to hit 25 lbs of boost. That was done part of the development testing we did on the valves.
dfuser is offline
post #6 of 7 (permalink) Old 05-10-2006, 12:16 PM
Great approach, I would also add:
#7 Check the Gauge (making sure it is not defective), and the line to the gauge for kinks or debris.
dfuser is offline
post #7 of 7 (permalink) Old 05-10-2006, 08:37 PM
#7 Check the Gauge (making sure it is not defectove), and the line to the gauge for kinks or debris.
#7 :agreed: :agreed:
