illumination problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sstockton, this thread has received 3 replies and been viewed 512 times.
post #1 of 4 (permalink) Old 05-10-2006, 02:37 AM Thread Starter
I have a 94 F250, that was originally a canadian truck, and I'm having trouble with my lighting system.
pretty much the deal is, I can't get my headlights and illumination lights on at the same time. No illumination lights also means no tail lights, which is just an added extra pain in the neck. There is a precarious position if you jiggle the switch just right both will work.
with that said, I figured it was the switch. I replaced the switch, and it was to no avail. So I replaced the pig tail that plugs into the back of the switch, and still nothing.
I removed the cluster and checked everything and it all seems fine. So I'm all out of ideas, any help or suggestions would be greatly appreciated. Has anyone had this problem before.
post #2 of 4 (permalink) Old 05-10-2006, 03:12 AM
Diesel Dog's Avatar
If I'm not mistaken and I may be..... I think the switch opperates a relay or two and that would be where the problem lies.
Diesel Dog is offline
post #3 of 4 (permalink) Old 05-10-2006, 06:18 AM
Make sure you have a good connection everyhwere and that the grounds are good. Bad grounds will do really wired things.
gtspowerstroke is offline
post #4 of 4 (permalink) Old 05-10-2006, 01:01 PM
BJS
no relay on the OBS trucks all of the power runs through the headlight switch.
I had a very similar problem on my old ranger and after hours with wiring diagrams and testing and probing with multimeters I found that I had an intermittent connection where the wire passed through the firewall providing power to the switch. I ended up running another wire to the switch and splicing it in because of the design of the passthrough on the firewall.
BJS is offline
