fuel pump relay - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moose99psd, this thread has received 32 replies and been viewed 6819 times.
post #1 of 33 (permalink) Old 05-13-2006, 02:33 AM Thread Starter
moose99psd's Avatar
fuel pump relay
ok guys here goes... about 2 weeks ago i stop to get fuel i shut the truck off i put fuel in her and go into pay come out get in the truck and turn the key wait for the light go to start it and it wont start :barf: :umno: this cant be happening.... so i look up and my fuel pres guage reads 0 so i get out and pull the fuel pump relay and swap in the hvac relay :Thumbup: starts right up and im on my way.. so tonight i go out to taco bell.. the lady asks me to turn off my truck to order so i do i go to start it back up NOTHING AGAIN! no fuel pressure so i open my glovebox and get out one of the backup relays i bought after the first mishap... put it in and vroom were up and running again....now im getting peeved... pull into the drive and just for ****s and giggles i shut it off turn the key back on about 30 sec later no fuel press again... so i shove the relay i took out at taco bell back in and turn the key... FUEL PRESSURE YAY!!! no im REALLY pissed off whats going on with this thing guys...
moose99psd is offline
post #2 of 33 (permalink) Old 05-13-2006, 03:26 AM
Ol Dirt Contractor
Lowboy's Avatar
Sounds like it might be a connection loose in the relay block. I'd try to remove and reinstall the same relay next time it does it.:shrug:
If just wiggling the relay gets the pump to work that would confirm a bad relay plug connection..
I was Anti-Obama before it was cool!
Leno: ‘Remember the Old Days When Obama’s Biggest Embarrassment Was Joe Biden'
Ernie Hasse+ Bill Gaither America Medley
XCR 800cc Polaris Triple with Turbo, Nitrous & RMI
96 F250 7.3 Hypermax Stage III’s, H2 for now, Wide Open Performance long block. Spearco Intercooler 4” downpipe Suncoast Tranny, Terminator Oil
Newest--2015 Black VW Golf SportWagen TDI DSG Nav Roof 18" Avignon's Valentine One
Early 99 F250 SD 7.3 almost stock for now
87 Turbo Intercooled T-Bird stock
98 379 Pete 15.8L CAT 3406E 5DS Borg Warner 175963 Turbo P5 Nathan Horns Johnson Matthey 600 HP DPF 2017 CA registered emissions legal
More Milwaukee V28 Tools than Tim Allen has!
Remember, nozzle size matters at the pump
Lowboy is offline
post #3 of 33 (permalink) Old 05-13-2006, 03:37 AM Thread Starter
moose99psd's Avatar
but things dont get "get back connections" specially seein how i hadnt even opend the cover for those relays since i bought it almost 2 years ago oh and its an SOB to pull out
post #4 of 33 (permalink) Old 05-13-2006, 04:00 AM
your pump fuse has not blown? have you ever replaced the pump fuse?? i ask because the last time i replaced a fuel relay someone jamed a piece of wire in place of the fuse.:evil: the pump was going bad and would pull alot of amps,the wire was heavy enugh to hold so the relay would get hot and brake connection. start your truck reach under the dash and do a wire wiggel test. grab every wire bundel you can and wiggel it. now do the same on the wires under the hood by the pcm. if you have a biased wire or connection wiggeling will help find the source. you will know if this is the case because your truck will die.:Thumbup: does your fuel pump sound louder or have you seen a psi change lately????
imported_diesel71 is offline
post #5 of 33 (permalink) Old 05-13-2006, 04:07 AM Thread Starter
moose99psd's Avatar
ever since day one of the guages the psi never stays the same changes day to day... its quite annoying
post #6 of 33 (permalink) Old 05-13-2006, 04:25 AM
what kind of psi are you seeing? your fuel pump may be what is causing the relay to brake connection? seems odd but it can happen.
post #7 of 33 (permalink) Old 05-13-2006, 05:10 PM
CSIPSD's Avatar
Ya, that sounds strange? Mine will hold steady at 68-69 unless I'm on it hard then it drops to 60-64... How old is the fuel pump? Have you done the pre pump mods?
CSIPSD is offline
post #8 of 33 (permalink) Old 05-13-2006, 05:49 PM Thread Starter
moose99psd's Avatar
it will fluctuate on my guage anywhere from 60-70 i have it set at 70 so it may be the guage not reading right havent looked at the guage on the regulator the pump is stock oem... think i may sell myself and get the rest of the itp fuel system and finish it off
post #9 of 33 (permalink) Old 05-13-2006, 10:49 PM Thread Starter
moose99psd's Avatar
ok so my itp guage on the reg stays firm at 70lbs but my guage in my truck says 60 :shrug: ok and i found out today that even if i start it up and shut it off lettng it run as short as a minute and try to restart no pressure... if i let it sit for 30 seconds it starts:shrug: man im freakin lost ill keep going back to a fuel pump on the shyts...
post #10 of 33 (permalink) Old 05-13-2006, 11:04 PM
CSIPSD's Avatar
I'm not sure... thats a tough one...
CSIPSD is offline
