7.3 Emergency - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jschall, this thread has received 40 replies and been viewed 1459 times.
post #1 of 41 (permalink) Old 05-13-2006, 02:42 AM Thread Starter
7.3 Emergency
Hi yall,
I bought my wife an xcal2 with a custom tune for her 02 4x4 Excursion..and followed all the rules...but it just cranks no start..so I put it back to stock and still it just cranks no start..When my 96 did this twice it was a glow plug relay but Im wondering if I could have blown a fuse programing it or something...I checked the strategy and it is back to stock....Im in the dog house and on the couch if I don't fix this...please help....please...
j.schall
jschall is offline
post #2 of 41 (permalink) Old 05-13-2006, 02:53 AM
Diesel Dog's Avatar
First thing that comes to mind is the fuel bowl heater fuse.
I think it's under the hood, don't remember the # but it's a 30 amp "big" fuse
If it's blown replace it and un-plug the fuel bowl heater.
Second thought would be cps
Diesel Dog is offline
post #3 of 41 (permalink) Old 05-13-2006, 02:56 AM
Can you check for codes? or better yet how about looking at the data stream while cranking? look at the tac when you crank,if it does not move you have no cps signal. i had this happen once. you can check all the fuses. are you getting any smoke ouy the tail pipe?
imported_diesel71 is offline
post #4 of 41 (permalink) Old 05-13-2006, 03:02 AM Thread Starter
I will go try and crank her and look at the tach... no smoke out the pipe yall sounds perfectly normal...it just won't kick off like normal...It has been a perfect beast maintenace free untill I try to program it...lol...let me check those things and get back..can't figure out why the fuel bowl heater would cause such a mess the fuel sitting in it should be a good 85degrees but because my 7.3's have been so reliable Im very ignorant about them...more to come...
j.schall
jschall is offline
post #5 of 41 (permalink) Old 05-13-2006, 03:05 AM Thread Starter
Tach is not moving....while she cranks....??
j.schall
jschall is offline
post #6 of 41 (permalink) Old 05-13-2006, 03:06 AM
BJS
the fuel heater is on the main fuse for the IDM when it blows the fuse the truck stops running, nice engineering there. However the SD trucks have a heater design that doesn't tend to blow out as easily as the early trucks but it has still happened.
BJS is offline
post #7 of 41 (permalink) Old 05-13-2006, 03:07 AM
Diesel Dog's Avatar
If you have a spare, I'd swap it in to check. You wouldn't be the first to have one puke!!
post #8 of 41 (permalink) Old 05-13-2006, 03:12 AM
useually when the tac does not move you have a bad camshaft position sensor. do you have a cps sensor to swap out and try??
post #9 of 41 (permalink) Old 05-13-2006, 03:15 AM Thread Starter
I can try and get one tommorow the parts dept. at the ford house is open...why would loading a tune do this?? The truck took the kids to school and picked them up today with no signs of anything according to my wife...I am going to try and pull some codes...more to come..
j.schall
jschall is offline
post #10 of 41 (permalink) Old 05-13-2006, 03:19 AM Thread Starter
p1000 and p1260....mean anything ???
j.schall
jschall is offline
