which diff? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SICKS-O, this thread has received 16 replies and been viewed 879 times.
post #1 of 17 (permalink) Old 05-13-2006, 10:10 PM Thread Starter
Slow 6.0
which diff?
my truck has an open rearend, its aweful for traction, in the rain, snow or off road the truck barely moves. i want to upgrade to a posi but im not sure what to go with. limited slip, locker, trutrac? what do u guys use and what works? not to sound like a knuckle head but i like to burn tire every now and again so whats gonna handle 700ft lbs and lay down two stripes?
2006 F350 XLT 4x4
SICKS-O is offline
post #2 of 17 (permalink) Old 05-13-2006, 10:36 PM
moose99psd's Avatar
depends on how much money you want to spend... if it was me and i had the money i would go with either a e-track by detroit or an arb both are switchable lockers... both worth every penny this way if u dont want to have the locker on just turn it off
moose99psd is offline
post #3 of 17 (permalink) Old 05-13-2006, 10:40 PM
a locker is almost bullet pruff. but your tires will wear faster and mpg can go down abit.
imported_diesel71 is offline
post #4 of 17 (permalink) Old 05-14-2006, 04:18 AM
Ramprat's Avatar
I like my Detroit Locker, it's a tad skittish on ice, but otherwise no complaints.
Ramprat is offline
post #5 of 17 (permalink) Old 05-14-2006, 03:49 PM
I want to eventually get wid of hte LS and put in front and rear lockers. I am looking at the ARB when I do swap
en4cr is offline
post #6 of 17 (permalink) Old 05-14-2006, 04:43 PM
moose99psd's Avatar
arb are expensive but worth EVERY PENNY and great that u can turn them off at the flip of a switch... u could also add a tank and some airhorns with it cuz uve allready got the pump
post #7 of 17 (permalink) Old 05-14-2006, 06:09 PM
CSIPSD's Avatar
I like the e locker... a limited when off and a full licker when on, but do they have it for our Sterling?
CSIPSD is offline
post #8 of 17 (permalink) Old 05-14-2006, 06:18 PM
Ramprat's Avatar
When I was researching lockers for the truck the e-lockers were new & they did make em, but they were not strong enough to deal with the power and abuse the PSD was able to produce.
After mutiple e-mail exchanges with **** Cepek and other web forums I went with the Detroit Locker as the Detroit was even stronger than the ARB and less suceptiable to dammage or problems & was the only locker strong enough to take the power/torque that the PSD dished out.
However, that was back in 98-99 so I'm sure they have improved somewhat, but I still don't like the idea of the ARB or E-locker from a 100% reliabilaty standpoint where a Detroit will never fail unless the rear end goes PRANG:Thumbup: :Thumbup:
Ramprat is offline
post #9 of 17 (permalink) Old 05-14-2006, 06:31 PM
moose99psd's Avatar
i ran a arb in a jeep with 38" boggers and gears that wernt low enough for em every day never had one bit of a problem with them the arbs are strong as all get out id put one in and never second guess myself
post #10 of 17 (permalink) Old 05-14-2006, 06:51 PM
Ramprat's Avatar
Saw several jeeps have problems at the 99 EJS in Moab & one guy was so pissed he was going to switch over to a locker:shrug: When hard core off roaders don't like something, there has got to be a reason I'd say. ARB's were orginally designed for front end applications & not rear axles. In a front end you do not want a locker 24/7 and bad things will happen if you have one, thus the ARB was born.
It all depends on what you want & where you go wheeling. We go places that the only way you will get help is by sat com or somebody happens along. Otherwise you are on your own. I was something that is 100% reliable and bulletprof & not going to break down when out in the boonies.
With the ARB air leaks were a problem & are a potental problem area I don't want to dork with. We have a sun air II onboard air compressor & it's always had air leaks, never have been able to get rid of em all.
Ramprat is offline
