Brake issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Tates97, this thread has received 5 replies and been viewed 560 times.
post #1 of 6 (permalink) Old 05-14-2006, 12:18 PM Thread Starter
Brake issue
My Abs light popped on a few days ago. LAst nite the pedal wouldn't go down but about an inch.but still stopped the truck. This morning the light is gone but it only feels like the front brakes are working. Any ideas? Tate
Tates97 is offline
post #2 of 6 (permalink) Old 05-15-2006, 02:08 AM
BJS
More than likely your vacuum pump is shot. check to see if the climate control switches work they are also operated by vacuum.
pumps are around $100 IIRC, you need a powersteering pully puller to swap the pully over to the new pump.
BJS is offline
post #3 of 6 (permalink) Old 05-17-2006, 02:23 AM Thread Starter
Yes they work as does the cruise. Still think its the VP? Thanks Tate
Tates97 is offline
post #4 of 6 (permalink) Old 05-17-2006, 03:18 PM
BJS
from your description it sounds like your brakes are operating just as well as they would if the truck was not running hence the vacuum pump diagnosis.
As I noted on the other board it takes very little vacuum to operate dampner panels but far more for vac assist brakes.
Unplug the vac line going to the master cylinder and start the truck you should feel a very strong sucking force when you put your finger over the pump similar to what you feel when you put your hand over the end of a shop vac tube.
Or you could go buy a vac guage.
BJS is offline
post #5 of 6 (permalink) Old 05-17-2006, 08:14 PM Thread Starter
thanks I'm not trolling or ignoring I'm just used to nothing from "over there" that i have gotten to rely on these two for help... Now I understand. THANKS i will check it out ...tate
Tates97 is offline
post #6 of 6 (permalink) Old 05-18-2006, 02:09 PM
BJS
not the real "over there" (tds) but over on SDD.
BJS is offline
