2002 7.3L overheating - fan clutch?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3L Digger, this thread has received 1 replies and been viewed 804 times.
post #1 of 2 (permalink) Old 03-01-2016, 05:28 PM Thread Starter
Guys,
I need some help. On my last trip towing, my SD overheated on climbs. Pulling off the road and waiting on Park or Neutral cooled the engine down. I had to do this a few times to make it home without killing the engine.
I checked the coolant level and it is fine. No smoke on the exhaust. So I don't think I have a bad gasket.
I replaced all hoses and installed a new thermostat, it was time to do it. But the overheating does not go away.
Could it be the fan clutch? I am able to turn the fan by hand with very little effort when COLD. When HOT or at normal operating temp, it takes the same effort or less to turn the fan by hand. Should the fan be more difficult to turn when HOT? I am trying to determine if the fan clutch is the problem since the radiator and the A/C condenser are clean to allow air to pass through them.
Any thoughts? Thanks
7.3L Digger is offline
post #2 of 2 (permalink) Old 04-25-2016, 01:19 AM
I ended up putting a radiator in mine. Seems there bad about clogging up in the bottom fins. Tried blowing it out and then just bought a new one. (not from ford either)
Have not had problem since.
Drake is offline
fan clutch and snow plow fan clutch??? bootcamp 2003-2007 6.0L Power Stroke 1 12-21-2010 03:15 AM
fan clutch and snow plow fan clutch??? bootcamp General Ford Truck and Excursion 1 12-20-2010 01:37 PM
6.0l fan stopped again, will a manual fan clutch work WasGas 2003-2007 6.0L Power Stroke 11 10-28-2009 02:09 PM
Electric fan versus fan clutch debate revisited Lonesome7.3 1994-2003 7.3L Power Stroke 33 09-12-2006 06:10 AM
Electric fan or fan clutch???? Lonesome7.3 1994-2003 7.3L Power Stroke 10 02-22-2006 02:29 AM
