1997 7.3L Powerstroke No Start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RedTruck, this thread has received 3 replies and been viewed 1023 times.
post #1 of 4 (permalink) Old 03-06-2016, 06:42 PM Thread Starter
Hello! I have a 1997 7.3L Powerstroke F350 Crew Cab 4x4.
It cranks over but does not start. Drove it two weeks ago no problem. Changed oil, turns over fine, Tachometer moves during cranking, no WTS light.
Replaced Glow Plug Relay.
Verified Fuel Filter Housing full.
Good batteries.
Any ideas out there would be appreciated.
RedTruck is offline
post #2 of 4 (permalink) Old 03-08-2016, 07:39 AM
Jasong's Avatar
Hmmm, since no-one else has answered I'm going to stab at it.
There should be a shutoff solenoid on the fuel pump. The connector could be loose/broken/fuse/etc. It should get 12 volts when on/cranking.
Jasong is offline
post #3 of 4 (permalink) Old 03-08-2016, 06:54 PM Thread Starter
Thank you for your response Jasong. I verified the fuses are good and will check the shutoff solenoid.
RedTruck is offline
post #4 of 4 (permalink) Old 03-10-2016, 03:43 PM Thread Starter
Ok update as follows.
It appears the problem is the PCM. Now the trick is finding the right one. I have not been able to find a new, reman., or used, that match the my existing numbers.
Can anyone tell me if I can use another PCM that is for that year range truck with matching options? Numbers on my PCM are- (DPC-312), (F7TF-12A650-RC), and calibration code on door (7-90-P). The truck is a 97 F350, 7.3L diesel, 4x4, crew cab, automatic.
RedTruck is offline
1997 7.3L Powerstroke No Start RedTruck Introductions 0 03-06-2016 06:33 PM
1997 powerstroke for sale. Stacked6600 Vehicles For Sale 0 09-21-2010 01:05 PM
1997 powerstroke mods? DmsFab 1994-2003 7.3L Power Stroke 8 09-12-2009 04:15 AM
1997 Powerstroke F350 CC LB circle5 Whats Been Sold 12 05-01-2008 05:36 PM
1997 F-350 Powerstroke fuzzys69 Whats Been Sold 47 02-21-2007 02:44 AM
