7.3 smoke and clanking problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3power, this thread has received 2 replies and been viewed 440 times.
post #1 of 3 (permalink) Old 05-15-2006, 06:17 PM Thread Starter
i am from southern nh and it has been raining for days . i went to start my truck this morning and it was running smooth then died so i let it sit i started again and it ran for a while and it started to make a clanings sound and black smoke i think it is something with the injectors.i am not sure. it runs smooth and it clanks and then back to normal please help me!!??!?
7.3power is offline
post #2 of 3 (permalink) Old 05-16-2006, 03:08 AM
4cstr
With all the rain you've had up there...have you drained your fuel bowl? Also...you may have gotten some bad fuel. Those might be the cheapest and easiest things to check first.
And welcome to the site.
post #3 of 3 (permalink) Old 05-16-2006, 06:08 AM
sounds like an injector missing? do you have a way to get codes?? that would help alot. you may have a under the valvecover wire connector loose. try running the engine,grab the wires were they go into the valvecover and wiggel them. if it smooths out or you can make it clank its a wire connector under the valve cover.
imported_diesel71 is offline
