OVER HEATING - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by festejr, this thread has received 1 replies and been viewed 835 times.
post #1 of 2 (permalink) Old 09-03-2017, 01:29 AM Thread Starter
OVER HEATING
Hey..
I have a 2000 F250 and I cant get it from over heating.
The water doesn't seem to be that hot so I'm thinking its blocked from going through the engine.
I checked the thermostat , fan , water pump and cleaned out the radiator.
When I took off the hoses a lot of hot steam came out before the water.
Has anyone else had this problem , if so what should I do.
Robert
festejr is offline
post #2 of 2 (permalink) Old 09-04-2017, 05:45 PM
Stuck in Commiefornia...
IdahoF350's Avatar
Have you verified the actual temperature? A bad temperature sending unit or a short in the wiring can pin the gauge hot. A thermostat stuck open will overheat under loads and run cold at cruise speeds especially going downhill, on the other hand a thermostat stuck shut will get the engine hot and keep it that way. Water pumps can fail without leaking, I've seen the impeller come off of the shaft or spin on the shaft. Radiators on these trucks are not usually a problem but the coolant bottle can be. If your coolant bottle is cracked the system won't hold pressure and without pressure the coolant will begin to boil at just over the temperature water would boil at without the added pressure the cooling system is designed to operate with. And of course don't neglect the coolant bottle cap, they can and do go bad and when they do they can cause overheating for the same reason as a cracked coolant bottle.
Verify with a mechanical or infrared gauge that the truck is actually overheating or getting as hot as you think it is. To test the water pump, get the truck hot and turn on the heater full blast. If the heater starts out rocket hot and then cools off you have a coolant flow issue and I would suggest replace the thermostat and water pump, both have issues, and both have been replaced on my truck in the past two years.
2000 Excursion XLT 4x4
IdahoF350 is offline
Over Heating Kristifer 2003-2007 6.0L Power Stroke 22 10-02-2009 12:58 AM
Truck over heating baplasma 2003-2007 6.0L Power Stroke 13 06-17-2009 11:29 PM
heating oil? C.S.Langanservices 6.7L Cummins (2007.5-2011) 14 04-12-2009 02:06 AM
engine over heating breck84 5.9L Cummins (2003-2007.5) 6 04-21-2008 10:52 PM
heating the block Rcannon 2003-2007 6.0L Power Stroke 13 10-30-2005 01:10 PM
