Stock tranny and performance parts for a 95 7.3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GotTorque?, this thread has received 8 replies and been viewed 681 times.
post #1 of 9 (permalink) Old 06-06-2006, 12:49 AM Thread Starter
GotTorque?'s Avatar
Im looking into getting a 95 Powerstroke and I was wondering what the stock transmission can hold for hp? What are some good parts for them, I was looking at stacks, stage 2 intake, tuner/chip, banks techni-cooler, banks turbo housing,banks transcommand and autometer gauges. I just need to know what will be good for this truck.
2000 F-250
4x4 ECSB
4" DP - 5" Back - 8" Black miter
K&N Intake
Tony Wildman 6pos Chip
Stewart Warner Maximum Boost, Trans, Pyro
35" BFG KM MT's
Jensen 7" Flip out DVD/CD
10" Rockford Fosgate Subwoofer
2400w Rockford Fosgate Amp
Soon to come -
4"-6" Lift
HID's
05+Front end Conversion
Train Horns
GotTorque? is offline
post #2 of 9 (permalink) Old 06-06-2006, 12:54 AM
well if your talking about my truck the tranny i would add a shift kit and maybe a torque converter and a high performance valve body but that all depends on how wild you want to get
DBogo is offline
post #3 of 9 (permalink) Old 06-06-2006, 01:07 AM Thread Starter
GotTorque?'s Avatar
I was talking about your truck and another 95 I found.
2000 F-250
4x4 ECSB
K&N Intake
35" BFG KM MT's
Soon to come -
4"-6" Lift
HID's
Train Horns
post #4 of 9 (permalink) Old 06-06-2006, 05:50 AM
Definately a converter with billet cover, a shift kit. If you plan on adding higher flow injectors you will need more hardpart tranny upgrades. Don't forget downpipe and exhaust with the intake to lower EGT's. Save your $ forget the transcommand unless you buy an IDI diesel. Then you will need it to deal with a lower pressure/volume tranny pump. Transcommand filled a void in it's time. But companys tend to keep marketing their products even when the original problem is corrected. The fix happened in 1995 with a higher volume pump.
RacerX is offline
post #5 of 9 (permalink) Old 06-06-2006, 11:26 AM Thread Starter
GotTorque?'s Avatar
Alright sounds good, Im only 16 so I need to save a lot of money, so would it be alright to start out with exhaust, intake, tuner, cooler and turbo housing before I do the transmission work?
2000 F-250
4x4 ECSB
K&N Intake
35" BFG KM MT's
Soon to come -
4"-6" Lift
HID's
Train Horns
post #6 of 9 (permalink) Old 06-06-2006, 11:47 AM
you should be ok with those mods and nothing added to trans. it would be better to add a shift kit. they are under $100.00 and will help you can to the converter later when funds permit you.
LIPD is offline
post #7 of 9 (permalink) Old 06-06-2006, 06:41 PM
Yeah. If the build tag is on the tranny, verify it's a 95 up unit. They are mid strength on the evolution line and will handle the other upgrades you mentioned, but not bigger injectors. If your buying and should find out it has an 89-94 E4od just rebuilt or not, adjust your offer. Their weaker designs and would need some hard parts that aren't put in a regular rebuild.
RacerX is offline
post #8 of 9 (permalink) Old 06-10-2006, 03:41 PM
check my sig that is with a stock tranny.i pull a 1972, 24 foot wilderness trailer just fine and fast as i want pretty much i just got a custom valve body from B.T.S. and got my chip reburned by Cale im putting it in monday so i will keep you posted on how it is. kirk
DieselDadio is offline
post #9 of 9 (permalink) Old 06-10-2006, 04:05 PM
moose99psd's Avatar
if i were u id stay away from most things banks... but thats just me i dont really care of their products.. rather over rated... lookinto a spearco ic. i believe they make them for a obs and look into a ats housing.. again im NOT positive on the availibility for a OBS where in ct are you man? i grew up in glastonbury
http://shop.blackwidowdiesel.com/dis...g?productId=68 spearco ic
http://www.atsdiesel.com/ATSWebsite/...ngine_comp.asp
moose99psd is offline
