9 Speed trans??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by xnaibasx, this thread has received 5 replies and been viewed 852 times.
post #1 of 6 (permalink) Old 12-08-2006, 01:56 AM Thread Starter
9 Speed trans???
I got 4.11 gears and a 5 speed trans and it sucks on thw highway! 75 mph at like 2700 rpm. I know gear venders make a conversion to make it a 9 speed i got a feelin its might be a little pricey... so is there any thing I can do besides change the gears.
Thanks
Jim
xnaibasx is offline
post #2 of 6 (permalink) Old 12-08-2006, 02:25 AM
Thanks
Jim
Wow. My 4:10 rear runs at/touch under 2500 at 75mph. Sure that aint a 4:33??
I guess you could slow down?
I would guess you are getting about 12 mpg (possibly less?) at that speed? You MIGHT see 15 mpg at 2200 rpm/75mpg.....
If you drive some what regular number of miles per year, you might find that even spending money on gears would equal about a 4yr payback. Reality seems that an improvement of a few miles per gallon is not very much cash at the end of the year saved.
Duker is offline
post #3 of 6 (permalink) Old 12-08-2006, 02:48 AM Thread Starter
HAHAHA yea slowing down might help, But yeah im almost positive i got the 4:11 and my fuel mileage isnt that bad just wanted to get the rpms down a bit i do a lot of highway drive for 5 hours or more so. My friends got 3:73 i think and hes at 2200-2400 at 80 so...
but thanks
Jim
xnaibasx is offline
post #4 of 6 (permalink) Old 12-08-2006, 04:04 AM
bmoeller's Avatar
Getting a Gear Vendors or US Gear gearbox isn't going to pencil out very well, if you are hoping for better mileage. If you have several grand burning a hole in your pocket, or need more gears for towing, than go ahead and get it if you want.
Would probably be cheaper to do a gear change in the diff(s), or go with some even taller tires.
"Obama = Hoax and Chains"
bmoeller is offline
post #5 of 6 (permalink) Old 12-08-2006, 04:25 AM
Thanks
Jim
1997 F-250 5 speed
K&N intake
3" Down pipe
EDGE evolution
5" grandrock stacks
33 12.50 R16.5 wheels
You've already increased your tire size by 6% therefore your rear end ration is about 3:88. When I ran stock tire with my 4:10s, I'd run 75 about 2350-2400rpm, but then when checked against mile markers and GPS I found that the speedo was running a little fast - probably saved me a ticket or two.
Did you use the edge to adjust your tire diameters? Have you verified the spedo calibration against a measured mile or a GPS unit? You may be running faster than you think. Gear vendors unit is very pricey!
1999.5 F350, PSD, CC, LWB, DRW, 4x4, assorted mods < PowerStrokeNation.Com >
http://banners.wunderground.com/weat...NJ/Boonton.gif
389SixPack is offline
post #6 of 6 (permalink) Old 12-08-2006, 10:46 PM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
Talking
my lil brother has a gear vendors in his '92 7.3L and it is awesome, yea its expensive but its pretty cool it dropped his rpm's -500. he used to do like 70 mph at 2300 rpm now its down to 1800, and he gets about 13-14 mpg but he's 16 and he loves to blow smoke.
i want one for my 99, when im doing 75 mph im doing like 2300 rpm so if i had that extra gear it would lower it down to 1800 and i could get a lil mileage and go faster.:evil:
SAM
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
