turbo surge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pleace69, this thread has received 13 replies and been viewed 889 times.
post #1 of 14 (permalink) Old 12-08-2006, 02:45 PM Thread Starter
turbo surge
I like the power that my truck has , but i would like to get rid of the turbo surge. I found this on ebay will fix the surge or is there something else i can do.
UPGRADED TURBO FOR 1999.5 TO 2003 POWERSTROKE LIKE NEW! Item number: 320059181747
pleace69 is offline
post #2 of 14 (permalink) Old 12-08-2006, 03:18 PM
40 hp by slapping on another "stock" turbo????? Yeah right.
Those claims are outrageous. Plus, you'd be better off keeping your stock turbo and getting an ATS housing. It's cheaper than his "buy it now" price, plus it's better than simply porting out the stock one. Look at how thin that inlet wall is.
The ATS housing has a 4" inlet, compared to the stock which is less than 3 inches. The design of the housing isn't to pull in more air like the seller here is claiming, it's to eliminate surge and the flawed design of the stock turbo that's on our PSD's.
Pocket is offline
post #3 of 14 (permalink) Old 12-08-2006, 03:18 PM
CSIPSD's Avatar
Can you get me a direct link? I think its the same turbo I looked at about six months ago... a stocker... But I could be wrong
CSIPSD is offline
post #4 of 14 (permalink) Old 12-08-2006, 03:28 PM Thread Starter
I tried to get you a direct link but no luck i dont know how.
pleace69 is offline
post #5 of 14 (permalink) Old 12-08-2006, 03:38 PM
Heres a link
Eric
Dually Club Member #53
racehauler is offline
post #6 of 14 (permalink) Old 12-08-2006, 03:52 PM
CSIPSD's Avatar
RUN AWAY RUN AWAY..... Thats just a stocker with a hacked compresser housing.... Not enough matterial there to get a clamp on it with out deforming it...
CSIPSD is offline
post #7 of 14 (permalink) Old 12-08-2006, 05:19 PM Thread Starter
Thanks, So will a ats housing and a wicked wheel be the way to go to elminate the turbo surge.
pleace69 is offline
post #8 of 14 (permalink) Old 12-08-2006, 06:42 PM
CSIPSD's Avatar
I had a ATS housing and a WW and 0 surge... but then I still upgraded to a bigger turbo... So think about how far you want to go...
CSIPSD is offline
post #9 of 14 (permalink) Old 12-08-2006, 10:05 PM
All you need is the ATS housing for surge. Adding the WW will give you even more whistle, but it won't provide any additional help with surge when coupled with the ATS housing. It's up to you on deciding if you want both. Or like CSIPSD mentioned, think about how much power you plan to add, then decide on where you want to go.
Pocket is offline
post #10 of 14 (permalink) Old 12-09-2006, 07:23 AM
laysonw's Avatar
For like 80 bucks you could eliminate surge and save the 3-400 something for another turbo down the road.
Good luck,
Steven
01 12.5" Icon, OUO Traction Blocks, Dynatrac Prosteer Balljoints, SpynTec Conversion, 40" Toyos, GTP38R, Isspro Guages, ORU Diff Covers, Hella 500s, AMP powerstep, Mini Me's, Heat Extractor Hood, custom paint, and BTS tranny!
New Truck Pics
Iraq War Heroes Tribute Page
laysonw is offline
