Guages - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 15 replies and been viewed 933 times.
post #11 of 16 (permalink) Old 12-14-2006, 07:49 PM
CSIPSD's Avatar
Wellllllllll, Sorry... I had a birthday to go to...
I prefer Isspro myself but have both. I would get a Pyro, boost, and Fuel pressure in your case. Fuel pressure is more important then Diff in MHO... I have yet to see a truck DOA from a bad diff, but have seen LOTs for bad fuel filters, pumps and the likes...
Check my pics for mounting options, the two gauge around the factory cluster is very nice if you just go with two...
Name:	Isspro lit at dusk.JPG
ID:	7774   Click image for larger version
CSIPSD is offline
post #12 of 16 (permalink) Old 12-15-2006, 01:56 AM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
How much of a sweep do I need on the boost?
POWER STROKE 99 is offline
post #13 of 16 (permalink) Old 12-15-2006, 02:16 AM
Diesel Dog's Avatar
If you have a stock turbo, 30-35psi will be all you need.
Diesel Dog is offline
post #14 of 16 (permalink) Old 12-16-2006, 03:23 AM Thread Starter
Should I buy the vaccum/boost or just boost and how much of a sweep on fuel pressure.
post #15 of 16 (permalink) Old 12-16-2006, 07:13 AM
A diesel will never pull vaccum so you only need a boost gauge. You will want a 0 to 100 psi fuel pressure gauge. I am not sure what the pressure is with a stock regulator (unshimmed) but we normally shoot for 60 ot 70 psi with a regulated return setup.
Eric
Dually Club Member #53
racehauler is offline
post #16 of 16 (permalink) Old 12-17-2006, 06:20 PM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
yea man dont buy a vaccum/boost guage thats wat i had then i traded up b/c it was a waste, b/c it will never pull any vaccum.
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
