Manual transmission - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 5 replies and been viewed 715 times.
post #1 of 6 (permalink) Old 12-14-2006, 07:16 AM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Manual transmission
My transmission grinds when you shift to third gear. I think it may be the synchronizer. Has any one ever did this?
POWER STROKE 99 is offline
post #2 of 6 (permalink) Old 12-14-2006, 07:20 AM
Mine grinds going into second both ways Up or Down, and down into first as well. Infact it more than grinds, it won't let you shift in unless you match RPM which makes it totally useless for compression braking. How many miles are on your truck? I'm guessing that you're hitting about the 140k range now.
post #3 of 6 (permalink) Old 12-14-2006, 08:12 AM Thread Starter
It has 246k, but if the odometer din't say this you wouldn't even know because it looks so good.
post #4 of 6 (permalink) Old 12-14-2006, 01:49 PM
Yep sounds to me like syncronizers for both of ya. I wouldn't grind her too long, you will be buying some new gears also.
Eric
Dually Club Member #53
racehauler is offline
post #5 of 6 (permalink) Old 12-14-2006, 06:38 PM
Wow, thats pretty good. I was just guessing because everyone I know with a manual ford which isn't too many people has started having synchro problems at right about 140k. Anyways, yeah mine is dying and I think it'll will just be driven until I can't stand it and then replaced. If I just throttle up before shifting in an it will slide right in,
post #6 of 6 (permalink) Old 12-14-2006, 06:41 PM Thread Starter
Mine is just the opposite, I have to the RPM's come down to around a 1 grand.
