Stock HP of A 99.5-03 Powerstroke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ramroid04, this thread has received 4 replies and been viewed 1521 times.
post #1 of 5 (permalink) Old 12-14-2006, 04:13 PM Thread Starter
What's the stock HP on a 99.5-03 Superduty???
ramroid04 is offline
post #2 of 5 (permalink) Old 12-14-2006, 04:20 PM
coreystroke02
coreystroke02's Avatar
I have a 2002 F-250 with the 7.3. Stock the truck makes 250 h.p. and 525 ft. lbs. The manual tranny makes 275 h.p.
coreystroke02 is offline
post #3 of 5 (permalink) Old 12-14-2006, 06:33 PM
TDG Mafia Member # 37
01blkf250's Avatar
I may be wrong but i believe the 99-2000 were rated at 235 hp and the 2001 MY was rated at 250 hp with the manual trans rated at 275 hp as mentioned above. Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #4 of 5 (permalink) Old 12-14-2006, 08:22 PM
CSIPSD's Avatar
Remember these numbers are at the flywheel... Sad but true, stock your putting down about 190-210hp to the rear wheels...
CSIPSD is offline
post #5 of 5 (permalink) Old 12-14-2006, 09:47 PM
I have seen valve cover tags from 235 california emissions to 250 on others.
DART505 is offline
