What's it gonna take to push 400 HP??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ramroid04, this thread has received 18 replies and been viewed 834 times.
post #1 of 19 (permalink) Old 12-14-2006, 04:21 PM Thread Starter
Hi, Ive got a 99.5 Powerstroke that needs some more grunt. I should have me a heavy duty auto tranny by Christmas so, no worries their. I want at least 400 HP that is as reliable as the truck is now.... WAZZIT GUNNA TAKE?
ramroid04 is offline
post #2 of 19 (permalink) Old 12-14-2006, 04:40 PM
Supporting Vendor
Injectors, turbo, Fuel system. You will probably want to swap out your HPOP since you have a 99.
Other things that can make the truck more efficent like a upgraded intercooler that will give you lower intake temps, and lower back pressure.
The cheapest way to 400 would be w/ Stg II injectors, swaping to single shoots so the HPOP can keep up, or Hybrids. If you wanted room to grow you could get some big oil 1st, and that will give you room to grow into any injector you would want to run. Give me a call if you want to talk about possible setups.
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 19 (permalink) Old 12-14-2006, 07:41 PM
CSIPSD's Avatar
My sig should put me right at 400hp... It's as far as I am going...
CSIPSD is offline
post #4 of 19 (permalink) Old 12-14-2006, 08:02 PM
Get a set of 250 cc hybrids, stick em in the truck get a chip to run them and you will be over 400 a smidge. Don't need an upgraded hpop, don't need a different turbo, don't need a fuel system, don't need headstuds, don't need big intercooler.
twildman is offline
post #5 of 19 (permalink) Old 12-15-2006, 03:27 AM
YEH right.
I was suprised at how easy it was to get to 350.400 required more money and more time and more money more time.It has gotten easier if you do it right the 1st time.I would go with TW recomendation but you will sooner or latter need a turbo.
kainers is offline
post #6 of 19 (permalink) Old 12-15-2006, 03:46 AM
I be Architect'n
My X only hit 312hp and 567 tq with the mods below. But I can only hit 20 psi of boost, can't seem to find my boost leak. Also, that was on B20
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #7 of 19 (permalink) Old 12-15-2006, 04:02 AM
It can be done on stock injectors with big oil, or stock oil (a late model HPOP) and hybrids. Either way, your going to need a turbo to keep the EGT's down (although big oil does a better job) I'd go with the TN drop-in from Black Widow (I believe he has them to fit both early and late '99). After that, exhaust and a chip and you're good to go!
Oh yea, GET GAUGES!!!
If you get big oil first, you'll have a lot more options later (when the urge hits you, and it will)
BONE STOCK
444turbodiesel is offline
post #8 of 19 (permalink) Old 12-15-2006, 04:13 AM
Show me 400+ on stock injectors with big oil
twildman is offline
post #9 of 19 (permalink) Old 12-15-2006, 04:17 AM
I believe 'TheHammer69' over on the other site did it, but I could be wrong.
EDIT: My bad, he hit 341/681, sorry my memory is fuzzy
It can be done with big oil and AC singles though (which aren't much bigger than stock)
BONE STOCK
post #10 of 19 (permalink) Old 12-15-2006, 04:19 AM
KRP
I don't think 400 has ever actually been done with stock injectors. Not without some propane anyway. People have come pretty close, and with the tuner there to tweak it on the dyno then maybe it could be done? Once anyway.
Once you start modifying things the reliability goes down, it's just the way it works.
KRP is offline
