Power Steering Pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sstockton, this thread has received 1 replies and been viewed 591 times.
post #1 of 2 (permalink) Old 12-14-2006, 06:54 PM Thread Starter
Power Steering Pump
Replacing the power steering pump on the truck, Is this pump self bleeding so I just have to jack of the front end and go full stop to full stop to get the air out of the lines, or is there something else I need to do to bleed this pump. Thanks,
post #2 of 2 (permalink) Old 12-14-2006, 07:41 PM
That is the way every other ps pump has been that I have worked on, but most of those were GM's. Im sure someone will be on to confirm it.
Eric
Dually Club Member #53
racehauler is offline
