Pressure regulator mod - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by diesel dan, this thread has received 10 replies and been viewed 3293 times.
post #1 of 11 (permalink) Old 12-14-2006, 10:52 PM Thread Starter
Destroked
diesel dan's Avatar
I need help finding the article on the 7.3 fuel pressure regulator mod. I cant find it. Anybody know where it is or have any tips?
diesel dan is offline
post #2 of 11 (permalink) Old 12-15-2006, 01:48 AM
Are you adding an aftermarket regulator or shim the stock one?
Eric
Dually Club Member #53
racehauler is offline
post #3 of 11 (permalink) Old 12-15-2006, 02:45 AM
I'M also looking for info on the same thing,shimming the stock regulator with #4 washers?...and is this a benificial mod to do?
imported_hotrod is offline
post #4 of 11 (permalink) Old 12-15-2006, 10:49 AM Thread Starter
Destroked
diesel dan's Avatar
I was just gonna shim the stock one for now. Maybe get a regulator after the Christmas insanity....
post #5 of 11 (permalink) Old 12-15-2006, 12:47 PM
Super limo owner
Send a message via Yahoo to Super Limo
I would like this info as well someone help us out
Kyle
2001 Ford F-350 crew cab long bed srw black gauges boost and pyro Dp 4 pos chip. Straight piped 4 in lift with 35`s . Acetone emblems
CAN YOU KEEP UP??
Everyone dies but not everyone lives
AKA COOLUA Got A NEW NAME!
LOOK AT MY NEW PICS
Super Limo is offline
post #6 of 11 (permalink) Old 12-15-2006, 02:27 PM
Super Moderator
4rcFed's Avatar
Images: 12
If you are looking to just shim the FPR, you can always refer to Steve Baz's site, if you don't already have it under your favorites. It is:
http://pages.prodigy.net/stevebaz/
I have only seen the BB deal. I have 'heard' of other methods, but have not seen them.
2008 Dodge 2500 Mega Ram, SLT, Powered by a little 'ol 408 cubic inch six cylinder!!!
Chrysler's warranty = Not worth the paper it is printed on!!!
Gone, but not forgotten!!!
1997 FORD F-250 HD
7.3L, XLT, Off-Road Package
3.55's, E4OD, 4wd, Dana 60 swap, 3" Sky RSK, 315/70/17's on Racelines.
4rcFed is offline
post #7 of 11 (permalink) Old 12-15-2006, 03:13 PM
That looks like good advice to me. I haven't every shimmed a stock regulator before but I took apart mine once to clean it. It wasn't too hard to do.
I could help you out if installing an aftermarket one in the future.
Eric
post #8 of 11 (permalink) Old 12-15-2006, 03:49 PM
TDG Mafia Member # 37
01blkf250's Avatar
Guys I don't know if this will help you or not, but I used a 4x40 stainless steel cap headed screw. To do this you need to pull the fuel line, and kind of bend it out of the way. Then you need to remove the two screws holding the block on. Be careful when pulling it as there is a spring inside. You should buy a couple of these screws and grind the heads down, grind one down to 0.650, and the other one down to about 0.700 . If you don't have vernier calipers you can use a Nickel for reference, as a Nickel is 0.650 thick. All you need to do now is place the screw into the spring with the head of the screw fitting into the recepticle for the spring, this shims the spring the easy way. Then reinstall the block and fuel line. You should check your fuel pressure at this point. I just used my compression tester gauge, by placing a barbed fitting into the gauge where the hose connects, then I hose clamped a 3 foot section of fuel line onto the drain at the back of the fuel bowl. Then just turn the key to the ON position and the pump will run for about 15 seconds and you now have your pressure reading. On my truck the 0.650 thickness netted me 68 psi so I went no further, I was satisfied as most will tell you 62-70 psi is optimal anyway. I don't have any pictures of this guys so sorry for that but I hope this helps. By the way I now have a regulated fuel return kit in place. Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #9 of 11 (permalink) Old 12-15-2006, 03:54 PM
i hear that the ideal pressure is around 70lbs.?
post #10 of 11 (permalink) Old 12-15-2006, 04:06 PM
Super Moderator
4rcFed's Avatar
Images: 12
Yes. Between 65-70 is optimal.:Thumbup:
1997 FORD F-250 HD
4rcFed is offline
