Question about installing gauge faceplate - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Super Limo, this thread has received 7 replies and been viewed 659 times.
post #1 of 8 (permalink) Old 12-20-2006, 12:26 PM Thread Starter
Super limo owner
Send a message via Yahoo to Super Limo
Just got a new faceplate for my truck. I dont want to screw up my needles and there readings. But once you turn the key off they all (zero out) so I should not have a problem right? Anyone ever install one of these?
Kyle
2001 Ford F-350 crew cab long bed srw black gauges boost and pyro Dp 4 pos chip. Straight piped 4 in lift with 35`s . Acetone emblems
CAN YOU KEEP UP??
Everyone dies but not everyone lives
AKA COOLUA Got A NEW NAME!
LOOK AT MY NEW PICS
Super Limo is offline
post #2 of 8 (permalink) Old 12-20-2006, 01:35 PM
I remember a post around here about these gauge face changes. You may want to do a search in the 7.3 forum for it. I know I read about the instalation and they recomended taking the truck for a drive and note the gauge readings before removal of the stock face plate, then when finished take the truck for the same drive in as close to the same conditions as possible and adjust the needles as necessary to repeat the original readings.
Eric
Dually Club Member #53
racehauler is offline
post #3 of 8 (permalink) Old 12-20-2006, 02:49 PM
CSIPSD's Avatar
You have to remove the cover from it, then drive it and mark where they are. Then you can remove the face and replace it. Then go for a drive and install the needles at the same locations... A real PIA...
CSIPSD is offline
post #4 of 8 (permalink) Old 12-20-2006, 04:41 PM Thread Starter
Super limo owner
im going to take a pic of it and give it a shot before and after
Kyle
CAN YOU KEEP UP??
LOOK AT MY NEW PICS
post #5 of 8 (permalink) Old 12-20-2006, 05:47 PM
I wouldn't get too worried about how perfect you get them back on. My uncle has been a tech. at ford for about 25 years and he told me that there was some question as to the accuracy of the gauges in one of their products. Ford replied that they are only a reference and should be monitored for normal ranges by the operator and will indicate weather or not you are in the "normal" operation range.
I have noticed that most of Fords gauges now days have only high or low makings and not specific numbers.
Just a little info I thought might be of intrest to you.
Eric
post #6 of 8 (permalink) Old 12-20-2006, 08:45 PM
laysonw's Avatar
http://www.forgotton.net/frame.html
Daryl has got a good write up on his gauge cluster! Check it out...
Good luck,
Steven
01 12.5" Icon, OUO Traction Blocks, Dynatrac Prosteer Balljoints, SpynTec Conversion, 40" Toyos, GTP38R, Isspro Guages, ORU Diff Covers, Hella 500s, AMP powerstep, Mini Me's, Heat Extractor Hood, custom paint, and BTS tranny!
New Truck Pics
Iraq War Heroes Tribute Page
laysonw is offline
post #7 of 8 (permalink) Old 12-20-2006, 09:09 PM
Destroked
diesel dan's Avatar
Kyle, its better to do it with the engine cold IMO. Therefore, engine temp. between the time you taking it apart and installing it doesnt change. When I put mine in I marked them going down the road and the engine dropped temp and my gauge was way off. Then, there is a slight incline in front of my house and when I put it back together my fuel gauge was also off cause the incline made my fuel level change....just a couple good tips to pass along. Just turn the key to on and wait for your glow plugs to quit pulling power and see where everything is at.
diesel dan is offline
post #8 of 8 (permalink) Old 12-20-2006, 10:01 PM Thread Starter
Super limo owner
Its all changed wating to get pics up. I like the looks and once I took the old one out and installed then new one I started my truck to keep it warm befor I put the needles back on
Kyle
CAN YOU KEEP UP??
LOOK AT MY NEW PICS
