still need a solid answer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SmokingIDI_7.3L, this thread has received 4 replies and been viewed 530 times.
post #1 of 5 (permalink) Old 12-22-2006, 05:44 AM Thread Starter
Question still need a solid answer
Need to know what rear end is in a 01 DRW 6spd dana 70, 80 ?????? and if any one knows where to find ARB locker??? Also this rear end has lots of play, what is the common cause of this, will it need all new parts or will the ARB center chunk take care of it????:shrug:
thanks
Scott
SmokingIDI_7.3L is offline
post #2 of 5 (permalink) Old 12-22-2006, 06:23 AM
It should be a D80, if it has a factory LS it is either the Powr-Lok or Trak-Lok.
You don't want the Powr-Lok if you're going to tow heavy, if it's a Trac-Lok you can rebuild it if it's not too far gone, they work pretty good when set up correctly.
Unless you just can't live without the ARB.
If it's a Powr-Lok, there's a good chance the differential housing is cracked, which would ruin the gears too.
That's why Ford went to the Trac-Lok.
BONE STOCK
444turbodiesel is offline
post #3 of 5 (permalink) Old 12-22-2006, 06:36 AM Thread Starter
where would i look for the crack BTW thanks for the info
post #4 of 5 (permalink) Old 12-22-2006, 07:54 PM Thread Starter
And how do i know wich rear end it is trac-loc or powr-loc
post #5 of 5 (permalink) Old 12-24-2006, 09:36 PM Thread Starter
Hello Anyone Out There????????
