replaced glow plugs...no success! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TheBAT, this thread has received 17 replies and been viewed 1421 times.
post #1 of 18 (permalink) Old 12-24-2006, 04:57 AM Thread Starter
Alright guys, I need your help. My truck has been having a rough time starting. The engine will crank like it wants to start, it blows white smoke, so I know it's getting plenty of fuel. After 5 minutes of me turning the key off and on the truck will finally start. It sounded like a glow plug issue, so I replaced the glow plug relay, didn't fix the problem. Had the batteries tested, they checked out fine. Had the glow plugs changed, I was told that I had 4 bad glow plugs. I was hoping that would have fixed my problem but still, having problems starting it...Any help would be greatly appreciated.
Kev
TheBAT is offline
post #2 of 18 (permalink) Old 12-24-2006, 12:29 PM
When was the last time the oil was changed?
If its low or dirty it won't do a good job firing the injectors. A;so a weak hpop willl allow leak down of oil and cause hard starting
powrstrkn' is offline
post #3 of 18 (permalink) Old 12-24-2006, 01:38 PM
Squatch's Avatar
I would check and make sure all of the connectors are ok. The OBS trucks liked to burn the the pins on either side of the valve cover gasket. If all the wiring is ok it might be time for a compression test.
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
post #4 of 18 (permalink) Old 12-24-2006, 07:32 PM Thread Starter
Oil was changed 1000 miles ago. Truck runs great after it starts, it's just getting it started.
TheBAT is offline
post #5 of 18 (permalink) Old 12-26-2006, 02:01 AM
i seem to be having the same trouble, i have to glow it about 10 times before it starts, maybe more, i put new glow plugs and harneses in it and it was good for a while but now its getting worse and worse every day. please help its there a timer or selnoid that could need replacing. and also when i drive the truck in the morning and most of the day the waste gate opens even when its warm and then when i give it more gas it goes back to normal.
thanks
STROKETHIS7.3 is offline
post #6 of 18 (permalink) Old 12-26-2006, 02:18 AM
mrector's Avatar
Check out the thread (HELP! no start) in this Forum.
Me and my bro posted on that thread some things to check.
Hope we can help! Good luck!:Thumbup:
89 w250 project truck
mrector is offline
post #7 of 18 (permalink) Old 12-26-2006, 03:40 AM
Blowby's Avatar
"Had the batteries tested, they checked out fine"
Make sure you have12.7 or better when testing. GP's will draw it down quite a bit. Turn the key to cycle the GP's and test voltage at that point. If the voltage is below 11.4 then batteries need to be addressed.
F250 Reg Cab / 11.56 Fuel Only / 10.94 Nitrous Dyno Run 10-2009
Dyno:
1086hp DynoJet# II Event, 2012
1052hp ATS Event, 2012
1032hp PFI Event, 2009
999hp PFI Event, 2011
996hp Morgan Charity Event, 2011
RIP - Wide Open Performance
Swamps Diesel Performance - Injectors & IDM
Gearhead Automotive Performance - Stage II Cam
Blowby is offline
post #8 of 18 (permalink) Old 12-26-2006, 04:43 PM
Super Moderator
John_G's Avatar
Check BOTH large terminals of the GPR with the "Wait to Start" light on, you MUST have bettery voltage on BOTH terminals, or the GPR is bad (measured to battery ground of course).
I vote for LIBERTY!
John_G is offline
post #9 of 18 (permalink) Old 12-28-2006, 12:11 AM
Kev
When you get in the truck in the morning, turn on the key, watch the volt meter instead of the WTS lite, when it pops back to normal, start it then & see what happens...Or wait about 30 -60 seconds before you start it. Turn the key on & leave it on....
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
www.fordtransmissioncure.com
Special thanks to RacerX USA
action4478 is offline
post #10 of 18 (permalink) Old 12-28-2006, 06:13 AM
FRANKEN STROKE
Check the oil level in the HPOP resivor, this will cause a hard start also if the oil is not staying in the resivor.
96 F-250 4X4,DP Tunner, EZmod, up graded IDM, custom drive shafts, staight axle up grade, 5-speed,head studs, bps bypass, dual HPOP's, AFE Filter, aeromotive fuel system, tubes, springs, oringed, copper head gaskets, 5" stacks (all chrome), south-bend dd clutch, H2E big spinny thing, some hugh-jazz injectors, 3" body lift (had to fit the turbo in), homemade traction bars fromt and rear, blood sweat & lockers!!
Four different trucks had to die to make this one!!!!!!!!!!!Thats why we call him FRANKEN STROKE! Too much fuel, and not enough money
Sled pulling in NC,TENN,VA,and anywere else theyll let us!!!!!
P.S. Dont be afraid of the sawzall! It can fix anything!
[email protected]
DONATIONS EXCEPTED!!!!!!
Franken-stroke is offline
