Injectors on 94 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Milwgearhead, this thread has received 17 replies and been viewed 1005 times.
post #1 of 18 (permalink) Old 12-27-2006, 03:55 PM Thread Starter
Injectors on 94
Does anybody know how to remove the injectors from a 94 7.3DI? I've gotten to them and I think I removed all the hardware, but they just don't seem to budge.
Milwgearhead is offline
post #2 of 18 (permalink) Old 12-27-2006, 04:25 PM
CSIPSD's Avatar
Check out this install sheet... should help.
http://www.beansdieselperformance.co...torinstall.htm
CSIPSD is offline
post #3 of 18 (permalink) Old 12-27-2006, 05:10 PM
FRANKEN STROKE
Make sure u release the oil and fuel pressure firts, then unplug the wiring, then remove the two 8mm bolts that hold it down. There is a removel tool out there to help, but i just use a small pry bar and gently pry up on them, put the pry bar under the hold down that the bolts were run through.
BE VERY CAREFULL WHEN U TRY THIS!!!! MISTAKES ARE $$$$$$$!!!!
Check the holes when u pull them out to make sure the copper ring off the end of the injector came out with it!
Hope this helps!:Thumbup:
NELSON
96 F-250 4X4,DP Tunner, EZmod, up graded IDM, custom drive shafts, staight axle up grade, 5-speed,head studs, bps bypass, dual HPOP's, AFE Filter, aeromotive fuel system, tubes, springs, oringed, copper head gaskets, 5" stacks (all chrome), south-bend dd clutch, H2E big spinny thing, some hugh-jazz injectors, 3" body lift (had to fit the turbo in), homemade traction bars fromt and rear, blood sweat & lockers!!
Four different trucks had to die to make this one!!!!!!!!!!!Thats why we call him FRANKEN STROKE! Too much fuel, and not enough money
Sled pulling in NC,TENN,VA,and anywere else theyll let us!!!!!
P.S. Dont be afraid of the sawzall! It can fix anything!
[email protected]
DONATIONS EXCEPTED!!!!!!
Franken-stroke is offline
post #4 of 18 (permalink) Old 12-28-2006, 03:35 PM
What he said^^^^^^^^. They are just pretty tight. I really had to pry on mine.
Jared S is offline
post #5 of 18 (permalink) Old 12-28-2006, 05:28 PM
Super Moderator
John_G's Avatar
MOST IMPORTANTLY!... Drain the oil from the oil rail on the head FIRST, let it drain a LONG TIME (30 minutes+) before you remove ANY injector on that bank. There are TWO small drain plugs under the valve cover, between the #1-2 injectors, and between the #3-4 injectors (from memory). These plugs are TIGHT, and cheap tools will not remove them. DO NOT remove the large plug on the rear of the cylinder head unless you have a GOOD Tq wrench, easy access, and a NEW plug from the dealer - or you will have an oil leak later.
Remove the one bolt you can reach, the other DOES NOT get loosened or removed.
Disconnect the wiring harness from the injector.
Using an angled screwdriver or prybar, CAREFULLY pry upwards on the bottom of the injector hold-down until it is free.
I vote for LIBERTY!
John_G is offline
post #6 of 18 (permalink) Old 12-28-2006, 05:51 PM
CSIPSD's Avatar
John, altho that is the Correct way of doing it, it is also the hard way. If you just remove the two rear injectors all the oil will drain into them (most...). Then hand crank the motor over when all the injectors are out and the oil will get pushed out... Do yourself a favor and put some rags over the holes... It comes out of there at a high rate of speed...
CSIPSD is offline
post #7 of 18 (permalink) Old 12-28-2006, 05:54 PM
moose99psd's Avatar
hahah yes yes it does.. also once ur all done and injectors are back in the holes.. pull the GPs and then crank the motor jumping the starter solenoid with the valve covers just lightly bolted in place and it will push the rest of the fuel and oil out. do this twice for 15sec. with a bit of a wait period to cool the starter
moose99psd is offline
post #8 of 18 (permalink) Old 12-28-2006, 06:18 PM
Super Moderator
John_G's Avatar
Removing two small plugs is hard?
Granted, it takes another couple of minutes, but to my way of thinking nothing beats KNOWING you will not bend a connecting rod.
I vote for LIBERTY!
John_G is offline
post #9 of 18 (permalink) Old 12-28-2006, 06:25 PM
i usually pull the injectors, intall new injectors, remove glow plugs and crank engine over to get oil/fuel out. Just make sure you put the valve cover on with a couple bolts or you'll have a nice mess to clean up.
lukecline is offline
post #10 of 18 (permalink) Old 12-28-2006, 06:26 PM
moose99psd's Avatar
you do have a point john. but that extra step takes alot longer.. and u pretty much are stuck doing nothing during that 30mins or so..
