Fuel pressure regulator??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by broadheadjohn, this thread has received 5 replies and been viewed 1517 times.
post #1 of 6 (permalink) Old 12-28-2006, 03:11 AM Thread Starter
How low is too low fow fuel pressure and how much is the regulator... I found one for 380$... that seems pretty steep... or do they have a rebuild kit for these??? Thanks guys..
broadheadjohn is offline
post #2 of 6 (permalink) Old 12-28-2006, 05:49 AM
What year of truck do you have?
I have a regulator off my 96. It should fit any OBS trucks and I will sell it for way less than that.
Eric
Dually Club Member #53
racehauler is offline
post #3 of 6 (permalink) Old 12-28-2006, 05:53 AM
FRANKEN STROKE
It would help to know what truck u need it for!
My 96 needs 24psi of pressure to run and 95psi at full boost (if u go by the guys selling the stuff) anyway u can buy a regulator (aftermarket) from most part stores or Summit, or any performance shop.
I paid $130 for mine it goes from 15psi to 100psi and is boost regulated(that means when the boost goes up so does my fuel pressure).
Hope this helps!
NELSON
96 F-250 4X4,DP Tunner, EZmod, up graded IDM, custom drive shafts, staight axle up grade, 5-speed,head studs, bps bypass, dual HPOP's, AFE Filter, aeromotive fuel system, tubes, springs, oringed, copper head gaskets, 5" stacks (all chrome), south-bend dd clutch, H2E big spinny thing, some hugh-jazz injectors, 3" body lift (had to fit the turbo in), homemade traction bars fromt and rear, blood sweat & lockers!!
Four different trucks had to die to make this one!!!!!!!!!!!Thats why we call him FRANKEN STROKE! Too much fuel, and not enough money
Sled pulling in NC,TENN,VA,and anywere else theyll let us!!!!!
P.S. Dont be afraid of the sawzall! It can fix anything!
[email protected]
DONATIONS EXCEPTED!!!!!!
Franken-stroke is offline
post #4 of 6 (permalink) Old 12-28-2006, 07:57 PM
*If* you are planning to do a custom fuel system / regulated return, here is what you need.
http://store.summitracing.com/partde...5&autoview=sku
Fuel pressure should be no more than 64psi steady, idle to wot, unless you want to place additional stress on the pump.
If you're having problems with the stock fuel bowl / regulator setup, now is the perfect time to do something about it. If you're willing to gather the parts and do the work yourself, you can do a custom fuel system with reg return for the $380 they want for the regulator you found.
gregrob is offline
post #5 of 6 (permalink) Old 12-28-2006, 11:22 PM Thread Starter
I have a 95 7.3L turbo by the way...
You say 64 psi "steady" My needle bounces back and forth every stroke...
post #6 of 6 (permalink) Old 12-29-2006, 01:13 AM
FRANKEN STROKE
The 94-97 7.3 engine uses a piston (or plunger) stile pump, just like the rockers the piston goes up and down as the cam goes round! The pump has a low side and a high side, it pumps both ways up and down this causes a slite drop in pressure(your gage is too sensitive so it seems to jump)!
Your pressure seems fine to me. I would check the screen I listed above because that is what caused my truck to fall off on top end and caused it to shutter when lugging. You might also check the HPOP pressure, if the HPOP
(High Pressure Oil Pump) is not providing enough pressure it will cayse the same problems.
By the way the 7.3 in these years used a single shot (From factory) injector they only need 24psi to start and idle, but i set mine at 50 psi at idle with my size injectors! It is an Aeromotive A1000 pump and dual inlet regulator, as Locomoton said he has listed a site for you. It was cheaper to replace my factory system than to rebuild it! But I would check the cheaper stuff out first like the screen! GOOD LUCK!
NELSON
[email protected]
