air bag light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordfanatic69, this thread has received 4 replies and been viewed 614 times.
post #1 of 5 (permalink) Old 12-29-2006, 07:06 AM Thread Starter
Smokin
fordfanatic69's Avatar
air bag light
my airbag light is on. What could possible be wrong with it. It is on my 01 F250.
09 F250 Crew Cab FX4
5% tint 35% whole windshield w/5% brow
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
5" Flow Pro No Muffin W/6" tip
Spartan 310
fordfanatic69 is offline
post #2 of 5 (permalink) Old 12-29-2006, 12:40 PM
fordt
My 7.3L does the same thing, I can't figure it out, it shows no codes on the NGS.
post #3 of 5 (permalink) Old 12-29-2006, 01:55 PM Thread Starter
Smokin
wonderful I guess i will just have a lil light on all the time.
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
Spartan 310
post #4 of 5 (permalink) Old 12-29-2006, 03:13 PM
plainredtruck's Avatar
Images: 11
Both of you:
When you start the truck, does it flash a certain # of times - pause, then flash a certain # of times more?
Or does it just come on and stay on?
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #5 of 5 (permalink) Old 12-29-2006, 04:40 PM
Squatch's Avatar
In the reg and ex cab trucks they have a pass air bag deativation switch on the dash. (stick your key in to turn on or off) It has a light that should light up and then go off when you turn the truck on. If it never lights up the bulb is bad and will set the Airbag light. The bulb is not servicable and you have to replace the whole switch. I bet we do 2-3 of these a week.
The other thing that is common is the clockspring under the steering wheel will get an open in it. Sometimes the cruise and horn will not work also.
Need to find out what code you have first!
06 F-350 Crewcab 5.9 CR
03 Excursion 6.0
99 F-250 7.3
97 Dodge 3500 5.9
95 F-250 7.3
Squatch is offline
