Pulsating lights - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ELKHUNTR, this thread has received 3 replies and been viewed 593 times.
post #1 of 4 (permalink) Old 01-01-2007, 04:15 PM Thread Starter
Pulsating lights
I have a pulsating light issue, dome lights, head lights dash all of them. My truck is a factory dual alternator and both are working fine, I find I can load the charging system with all available accessories and it does not get better or worse, Ac, fan on high all lights on, stereo with two huge amps cranked up. I put a meter on the truck and get about a 3/10th volt pulse approx. 14.5-14.7 or so at the alt post or battery post but the lights really go to town, lights off no pulse.
There were two other guys with the same problem on another forum with the same issue both single Alt. trucks, but never learned any more. One more point, this problem is at least 8 months and 11,000 miles since first noticed and RPMs dont seem to make a big difference (very Subtle).
Anyone out there run into this before?
Thanks,
Josh
Josh
2000 F350 PSD CC 4X4 AT LWB 3.73s 173,000AFE STAGE I, TN.BB, EIS 200CC HYBRIDS F5 DP TUNER 4" TURBO BACK, AEROTURBINE 4040XL, 5" STACKS, ISSPRO GAUGES,PRE AND POST TURBO PYRO, SCANGAUGE.
ELKHUNTR is offline
post #2 of 4 (permalink) Old 01-01-2007, 04:30 PM
Diesel Dog's Avatar
I have pulsating headlights after hitting a large bump. I need to check for loose connections and grounds. Your issue sounds to me like a bad voltage regulator. I have dual alts too, but am not sure how the voltage regulator is set up. (one in each alt or one external)
Diesel Dog is offline
post #3 of 4 (permalink) Old 01-01-2007, 05:53 PM
Super Moderator
John_G's Avatar
I agree with the voltage regulator being bad. But you have TWO, and the question is, which one.
Disconnect the regulator wire (quick connect) on the easiest one to reach, that will disable that alternator. If the problem still exists, it is the OTHER one at fault. Obviously, if it is now fixed, you found the culprit.
BTW, the regulators can be replaced inexpensively in your garage, if you can change oil, you can do this and save $250 on a "rebuilt" alternator.
If you decide because of time, mileage, or use that you should have a rebilt replacement, I STRONGLY suggest you look in the phone book for a LOCAL rebuilder (most auto machine shops can do this, or tell you where), and use them. It will NOT cost you more $$, and you get a better product.
I vote for LIBERTY!
John_G is offline
post #4 of 4 (permalink) Old 01-01-2007, 08:23 PM Thread Starter
Thanks JohnG, I will check it tomorrow while I am under the hood changing my GPR that convenently gave out on me today.
Josh
ELKHUNTR is offline
