turbo upgrade for 01 7.3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ho6.0, this thread has received 7 replies and been viewed 2784 times.
post #1 of 8 (permalink) Old 01-04-2007, 10:42 PM Thread Starter
Question turbo upgrade for 01 7.3
got a transs chip intake and exhaust for my 01 7.3 and i wanna get a tubo uprade whats the best upgRADE
ho6.0 is offline
post #2 of 8 (permalink) Old 01-04-2007, 10:53 PM
CSIPSD's Avatar
Turbonetics or a GTP-38r BB
I have issues with my BB, still have not got it back yet. Turbonetics is working good, little laggy but I have a .84 housing in the shop to try to see if it helps. Thanks to Brian at BWD.
CSIPSD is offline
post #3 of 8 (permalink) Old 01-04-2007, 10:53 PM
CSIPSD's Avatar
Also depends on what you want to do... Big injectors later? or staying stockish?
CSIPSD is offline
post #4 of 8 (permalink) Old 01-05-2007, 01:02 AM
2nd the tn love mine cant compare to the BB, but it is a surge free strong turbo.
puredieselpower is offline
post #5 of 8 (permalink) Old 01-05-2007, 03:29 AM
i personaly like the garrett powermax BB it made my old truck run great no surge or lag, great turbo but it only cost about 2 grand!!
STROKETHIS7.3 is offline
post #6 of 8 (permalink) Old 01-05-2007, 05:51 AM
TDG Mafia Member # 37
01blkf250's Avatar
I love my GTP38R, it spools quick, whistles like crazy, and I have not had any surge issues at all. I do not tow anything heavier than 8,000 lbs, so I have not had surge issues, some guys have had some surge with the GTP38R but they must be pulling heavier loads than me. You can also get the non wastegated version with different housing options that I have been told will eliminate surging. I think you would be happy with either of the turbos mentioned but as said above really depends on what you plan on in the future for mods. Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #7 of 8 (permalink) Old 01-05-2007, 06:10 AM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
wat about the hypermax H2? is that a good one? if you were going to keep stock injectors?
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
post #8 of 8 (permalink) Old 01-05-2007, 07:34 AM
Couple things
Drive pressure-surge
For stock injectors, I'd look at a TN with a .84-keeps same wheels and compressor but has a custom machined smaller turbine housing. Spools faster than a stock turbo-moves more air with a 91 MM wheel.
Attached is a stock 2001 turbo drive pressure versus the TN 1.00-before and after.
bbunting is offline
