99 7.3 shuts down in the rain - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by thw1, this thread has received 4 replies and been viewed 1836 times.
post #1 of 5 (permalink) Old 01-08-2007, 06:30 PM Thread Starter
Ihave a 1999 7.3 psd ford f 350 it only shuts down in the rain no codes just like i turned off the key then restarts with no problem
thw1 is offline
post #2 of 5 (permalink) Old 01-08-2007, 06:35 PM
circle5's Avatar
:shrug: I have no clue but am interested to see what the problem is :
circle5 is offline
post #3 of 5 (permalink) Old 01-08-2007, 07:57 PM
plainredtruck's Avatar
Images: 11
Being that it's a '99, I would tend toward electronics. Particularly the GEM under the dash. It's buried in with the fuse box and you need the size hands of a 5 yr. old with the strength of a 20 yr. old to get to it very well.
Do you have any other problems? Wipers, windows, locks, etc.
Could be any # of things . . .
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 5 (permalink) Old 01-08-2007, 08:01 PM Thread Starter
7.3 stalls when wet
no other problems just stalling like i shut off the key .but only when raining
thw1 is offline
post #5 of 5 (permalink) Old 01-08-2007, 09:09 PM
KRP
Leaky windshield+GEM module is no good and could certainly be the problem. Check the connector at the CPS also. The GEM module is easier to get out if you completely unbolt the fuse box so you can move and twist it. If you look under the dash you can probably see if water has been leaking in there or not.
KRP is offline
