Fuel milage - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 8 replies and been viewed 835 times.
post #1 of 9 (permalink) Old 01-09-2007, 11:40 PM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Fuel milage
I think my fuel milage is to low, I am only gettiing 12 to 13 mpg. I have changed the ful filter, air filter, oil. What else can I do or check?:shrug:
POWER STROKE 99 is offline
post #2 of 9 (permalink) Old 01-10-2007, 01:27 AM
CSIPSD's Avatar
Chip will help, might get you to about 15-17...
CSIPSD is offline
post #3 of 9 (permalink) Old 01-10-2007, 03:04 AM Thread Starter
I plan on getting one soon, but not sure what to get. I would like to get something that I can change depending on how I would like to run the truck.
I planned on contacting DP tuners, what do you think?
post #4 of 9 (permalink) Old 01-10-2007, 06:19 AM
i have the ts performance 6 position chip w/the other mods in my sig. and i have seen around the 20 mpg mark most of the time if i keep my foot out of it.
imported_99powerstroke is offline
post #5 of 9 (permalink) Old 01-10-2007, 06:27 AM
CSIPSD's Avatar
DP or Elite Diesel... Both are #1 in my book. TS is good too! They all will help your MPG's
CSIPSD is offline
post #6 of 9 (permalink) Old 01-10-2007, 11:08 AM Thread Starter
I have looked at the tuner you suggested and going to give them a call also.
post #7 of 9 (permalink) Old 01-10-2007, 11:16 AM Thread Starter
I am also running the stock air intake, should I upgrade to a aftermarket and if so which one?
post #8 of 9 (permalink) Old 01-10-2007, 11:30 AM
GotTorque?'s Avatar
I would upgrade to a open air intake and exhaust to help out because when my dad uses the programmer in his truck it sucks more fuel for some reason and we get like 12-13.
2000 F-250
4x4 ECSB
4" DP - 5" Back - 8" Black miter
K&N Intake
Tony Wildman 6pos Chip
Stewart Warner Maximum Boost, Trans, Pyro
35" BFG KM MT's
Jensen 7" Flip out DVD/CD
10" Rockford Fosgate Subwoofer
2400w Rockford Fosgate Amp
Soon to come -
4"-6" Lift
HID's
05+Front end Conversion
Train Horns
GotTorque? is offline
post #9 of 9 (permalink) Old 01-10-2007, 03:57 PM
CSIPSD's Avatar
A Tymar intake is great, good bang for your buck, about $50-$100 or an AFE stage2 is about the best Hi flow out but at $400 its a bit pricy
CSIPSD is offline
