southbend clutch options - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by biscuit_ford, this thread has received 3 replies and been viewed 1131 times.
post #1 of 4 (permalink) Old 01-10-2007, 02:27 AM Thread Starter
I have a 00 powerstroke with a six speed tranny, ts 140hp chip, cold air intake and exhaust and now my stock clutch slips. It even slips when the chip is only on the 50hp setting. So I am looking for a aftermarket clutch and I heard southbend is the best, but I dont know if I should just get a single disk or a dual disk clutch. I pull pretty heavy sometimes but I never sled pull and probable never will. But I want my clutch to hold up good because I drive pretty hard. So If somone could tell me some thoughts on either single or dual disk clutch.
biscuit_ford is offline
post #2 of 4 (permalink) Old 01-10-2007, 02:36 AM
Supporting Vendor
If you drive it a lot and you don't compete you want a single disk! We can carry South Bend clutches. I would recommend the Con OFE. Let me know if I can help.
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 4 (permalink) Old 01-10-2007, 02:40 AM
I have the same truck as you. I bought a new LUK clutch and i love it. I bought the LUK upgrand kit from www.carolinaclutch.com part #07-155/1.
pleace69 is offline
post #4 of 4 (permalink) Old 01-10-2007, 02:40 AM
pleace69 is offline
