My first oil change...? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by D-Man, this thread has received 5 replies and been viewed 715 times.
post #1 of 6 (permalink) Old 01-10-2007, 09:00 PM Thread Starter
2000 7.3l Book says 15qts. 14qts puts it at the full line.
I did change the filter of course.
Is the rest held in the oil pump? Do I need to add another qt?
D-Man is offline
post #2 of 6 (permalink) Old 01-10-2007, 09:03 PM
circle5's Avatar
On mine i fill it about 1qt or so over the full line. then after i start the truck i check it again and it sits about right on the full line
circle5 is offline
post #3 of 6 (permalink) Old 01-10-2007, 09:31 PM
CSIPSD's Avatar
I always fill mine one over the line...
CSIPSD is offline
post #4 of 6 (permalink) Old 01-11-2007, 01:09 AM Thread Starter
I should have said it was 14 qts. to the full line after running it and filling the filter. The reason I want to make sure is, I bought a '92 F150 with a 302 brand new. Did all my own oil changes. 5qts to get it to the full line after running it. Then found out it was supposed to have 6 qts with filter change which put it way above the full line (again after running it). I had to make a new mark on the dipstick to keep it properly filled. I'm not sure if they didn't put in the right dipstick or possibly the dipstick tube.
Just don't want the same mistake with this truck and run it a quart low.
D-Man is offline
post #5 of 6 (permalink) Old 01-11-2007, 08:05 AM
hmmm i always have put 14 in mine and thats all she wants i fill the filter with about a quart before install and also run it, still only takes a total of 15
just visiting is offline
post #6 of 6 (permalink) Old 01-11-2007, 08:42 AM
15 in the 7.3 across the board.
Logan is offline
