egt's?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by floridastroke, this thread has received 5 replies and been viewed 783 times.
post #1 of 6 (permalink) Old 01-10-2007, 10:49 PM Thread Starter
egt's??
what egt's should i be running with my obs, just put my egt and boost gauge in trying to get some kind of idea?? thanks jesse
floridastroke is offline
post #2 of 6 (permalink) Old 01-10-2007, 11:02 PM
Never over 1250 for any period of time,(Pre Turbo mount)
I run about 400-600 cruising around.
powrstrkn' is offline
post #3 of 6 (permalink) Old 01-11-2007, 02:01 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
I have seen 1000* climbing hills, mine is installed in the up pipe.
POWER STROKE 99 is offline
post #4 of 6 (permalink) Old 01-11-2007, 08:03 AM
while were on the topic i want to install mine i am going to go preturbo i am guessing i ned to remove the turbo so the chips dong get in the exhaust side, but where is the best place to put the probe and anyone have any tips on the install (OBS here)
just visiting is offline
post #5 of 6 (permalink) Old 01-11-2007, 08:49 AM
If you get under the truck on the driver's side, head toward the front, if you look up the side of the motor, you will see the manifold. You will see a 90 bend that goes up closest to you. You want to put the pyro just before that. You dont have to take anything apart. Just drill it nice and slow, grease your drill bit and your tap. Take your time, use pleanty of grease and re-grease several times to be sure and catch all the shavings. Once you have it tapped, take a pocket magnet (I used the telescoping type) and put it up in the hole and get any extra shavings. I have also heard several guys that use their shop vac while drilling an tapping also. Dont go over 1250* for more than 12 seconds or so, and if you want the best fuel economy, stay below 550*. Hope this helps, any more questions, just ask away.
Logan is offline
post #6 of 6 (permalink) Old 01-11-2007, 09:47 PM Thread Starter
i have mine on the manifold but my buddy put his right after the turbo no the downpipe caue he was lazy what should he be running if theres any difference oh yea 1 more ? i dont know why maybe because i just put it to power all the time to my fuse box but my gauge never goes below like 180-190 thats like 0 for it why is it doin that??
