7.3 boost and egt hookup? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6L strokin, this thread has received 4 replies and been viewed 1451 times.
post #1 of 5 (permalink) Old 01-11-2007, 11:57 PM Thread Starter
TDG Mafia Member#67
6L strokin's Avatar
i gotta friend that just bought a boost and egt gauge for an 02 7.3. two questions
how far from the turbo on the DP does the hole for the probe need to be? i was thinking like 6"?
on the boost, should he splice the line with a tee or drill and tap for it? if a splice which hose should he splice into? if a tap, is the the tube goin from the turbo to the bottom of the IC? Thanks!
Darin
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #2 of 5 (permalink) Old 01-12-2007, 12:05 AM
CSIPSD's Avatar
Darin
PRE TURBO PRE TURBO PRE TURBO!!!!! JUST YELL IT YOU YOURSELF!!!
Boost, you can tap the Y just after the turbo, or you can build a T with a brass 1/4" tee, two barbed 1/4" fittings and a 1/4" to 1/8" compression fitting
Please DO NOT WASTE A GAUGE WITH A POST TURBO PYRO!!!
ID:	8072   Click image for larger version
CSIPSD is offline
post #3 of 5 (permalink) Old 01-12-2007, 12:07 AM
CSIPSD's Avatar
Or he can delete the intake air heater and get his boost readings there...
CSIPSD is offline
post #4 of 5 (permalink) Old 01-12-2007, 02:52 AM
CSIPSD, why did you not drill and tap the exhaust manifold for the pyro insted of using the clamp on the tube?
Steve
Stircrazy is offline
post #5 of 5 (permalink) Old 01-12-2007, 03:13 AM
CSIPSD's Avatar
Because at the time thats what came with the gauge I bought. I will leave the drivers side that way because I drilled and tapped the manifold for my manifold pressure gauge. The Pasanger side will be a drill and tap pyro. No real differance.
CSIPSD is offline
