Over Boost Code Problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerstroken160, this thread has received 1 replies and been viewed 864 times.
post #1 of 2 (permalink) Old 01-14-2007, 12:08 AM Thread Starter
New Former Member
Ok, I was having a problem with the code being set when drag racing so I put a boost fooler in the Map wiring harness, It was working fine until I added a bigger turbo, im not running any more boost than I did before maybe 1-2 lb less, I don't understand it issed:
powerstroken160 is offline
post #2 of 2 (permalink) Old 01-14-2007, 01:04 AM
moose99psd's Avatar
i would pull that fooler in the harness and get a regulator from itp diesel and be done with it.. regulator is better than the fooler put in the map line because you dont loose any boosht just limit it...
moose99psd is offline
