Found fuel problem....but need help! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed97, this thread has received 12 replies and been viewed 793 times.
post #1 of 13 (permalink) Old 01-15-2007, 10:09 PM Thread Starter
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
Today I checked my fuel pressure...bad.
@idle= 45-50psi
@1500rpm= 35-45psi
@WOT= 25-30psi
So apparently I have a problem....is that cause by a weak fuel pump(what Ford calls a Transfer pump) or could it be caused by a bad regulator?
Thanks for the help
e99 leveled on 35s
250/80, modded s300, studs, springs, push rods, adrenaline, swamps tuning, racerx trans
BigRed97 is offline
post #2 of 13 (permalink) Old 01-15-2007, 10:23 PM
Super Moderator
John_G's Avatar
If the reguator goes BAD, the FP will be low all the time.
You could have something as simple as a restricted fuel filter not allowing enough FLOW under power. Restrictions on the inlet side of a pump cause low output pressure.
I vote for LIBERTY!
John_G is offline
post #3 of 13 (permalink) Old 01-16-2007, 02:13 AM Thread Starter
The Oracle
BigRed97's Avatar
the fuel filter is only a few months old, and i had it out a month ago when i did my hpop it was still clean and i cleaned out the bottom of the fuel bowl at that time
where should i look for restrictions?
what would be other signs that its the pump itself?
e99 leveled on 35s
BigRed97 is offline
post #4 of 13 (permalink) Old 01-16-2007, 03:44 AM
pontiacross's Avatar
there is a screen on the drivers side of the fuel filter that plugs up pritty commonly. If i remember rite you have to pull out two bolts that screw in from the side. then you can move a block that has a couple of lines going it to it, over just enough to clean the screen.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #5 of 13 (permalink) Old 01-16-2007, 03:48 AM
https://www.thedieselgarage.com/forum...1&d=1158384628
The block is the regulator, labeled in this pic.
Ross
Tow Rig
post #6 of 13 (permalink) Old 01-16-2007, 03:57 AM
Super Moderator
John_G's Avatar
The "sock" in the fuel tank can get clogged, not common but I have seen it a time or two.
Also, fuel HOSES can collapse internally, this is a favorite of the CAT 3406 engines. Done a few (hundred) of them.
I vote for LIBERTY!
John_G is offline
post #7 of 13 (permalink) Old 01-16-2007, 10:19 PM Thread Starter
The Oracle
BigRed97's Avatar
today i cleaned the screen,with no change.
it was dirty but not really clogged
is there a pre filter on these under the truck that could be clogged? if not i'll be putting a fuel pump in....
e99 leveled on 35s
BigRed97 is offline
post #8 of 13 (permalink) Old 01-16-2007, 10:32 PM
Super Moderator
John_G's Avatar
Only the "sock" in the tank.
I vote for LIBERTY!
John_G is offline
post #9 of 13 (permalink) Old 01-16-2007, 10:39 PM Thread Starter
The Oracle
BigRed97's Avatar
looks like its fuel pump time
e99 leveled on 35s
BigRed97 is offline
post #10 of 13 (permalink) Old 01-17-2007, 11:48 PM Thread Starter
The Oracle
BigRed97's Avatar
just for reference what should my pressure be at idle and at given rpm?
thanks
~Tim
e99 leveled on 35s
BigRed97 is offline
