help with 99 SD..... FAST? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigRed97, this thread has received 9 replies and been viewed 637 times.
post #1 of 10 (permalink) Old 01-16-2007, 02:38 AM Thread Starter
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
hi guys,
my friend has a late 99, DRW, AT, with 140k....started running rough and stalling on him. once it warmed up it was ok, its started and got worse in about a week's time...
now it will barely start and idle horrible for 30-45 second then stalls(kinda sounds like its running out of fuel) its to the point that the truck wont move
i just put a cam sensor for him, i knew those were a commong thing that could cause his symptoms....it didnt help
im stumped(not that i know a whole lot about diesels)
oh he did have a code for ICP performance...could a bad ICP cause the conditions above?
any help you all could give would be awsome....hes kinda in a bind so the sooner the better....
thanks
~Tim
e99 leveled on 35s
250/80, modded s300, studs, springs, push rods, adrenaline, swamps tuning, racerx trans
BigRed97 is offline
post #2 of 10 (permalink) Old 01-16-2007, 03:02 AM
In a bind? Im screwed! Truck has 115,000 but i really dont think that matters any more or less.
MYSHO1 is offline
post #3 of 10 (permalink) Old 01-16-2007, 03:37 AM
CSIPSD's Avatar
Sounds like a fuel pump to me... Check the fuel pressure, get a 0-100 gauge and install it on the drain line for the fuel bowl, clamp the drain line to the filter housing!!! It should be min of 45, any lower then 30 and its not going to run right. I would bet the ICP is a old code but it could have a cloged screen...
CSIPSD is offline
post #4 of 10 (permalink) Old 01-16-2007, 04:31 AM Thread Starter
The Oracle
BigRed97's Avatar
the icp code comes back every time after its cleared
cleaning the screen(regulator screen right?) the same on the sd's as the obs' ??
e99 leveled on 35s
BigRed97 is offline
post #5 of 10 (permalink) Old 01-16-2007, 04:38 AM
CSIPSD's Avatar
Yes it is but I really think its the fuel pressure...
CSIPSD is offline
post #6 of 10 (permalink) Old 01-21-2007, 01:07 AM
My 00 had the same code and it didn't have enough power to move itself.
Turned out to be injector harness coming unplugged under the valve covers.
Bought the locks from ford it took care of the problem.
derec is offline
post #7 of 10 (permalink) Old 01-21-2007, 01:17 AM
niether fuel issues nor injector issues will set an ICP system code
Icp codes are set by oil quality or supply issues ,bad icp sensors (they are known to split leak oil and read incorrectly and can cause no starts),bad iprs or ipr wiring and bad pumps.
if you can post the actual code description it gives us more to go on
Photos of The Beast
DOC
Docluv2577 is offline
post #8 of 10 (permalink) Old 01-21-2007, 08:24 PM Thread Starter
The Oracle
BigRed97's Avatar
thanks guys
i found the problem....ended up being so simple that we overlooked it in the begining.....
the galley plug on the rear of the right head had blown the oring, hence leaking oil....leaked about half of it out.....no oil=no start...
changed the oil(for now just until he gets the new pulg and oring) and she fired right up...ran rough for a minute then smoothed out
e99 leveled on 35s
BigRed97 is offline
post #9 of 10 (permalink) Old 01-23-2007, 04:13 AM
whose the goose....
MYSHO1 is offline
post #10 of 10 (permalink) Old 01-23-2007, 04:29 AM
so Tim... when you wanna do the next fix?
MYSHO1 is offline
